The JK build
Posted 24 July 2011 - 09:53 AM
Will that's about it . I need to get going, I have alot to do today.There's a sale today at the Pembroke Pines mall today that I don't want to miss & then I need to go grocery shoping, and then take Tommy & his friend to the movies.
Posted 24 July 2011 - 01:38 PM
Sign me up for build duty!
99 TJ - Wrangler Sport
Posted 24 July 2011 - 01:57 PM
I talked with Mike at 4 Wheel parts and he is more them willing for us to do the lift there.You are all welcome to come by and lend a hand.Before the time of each install, I'll post up if for some reason I can't do it that day.
The lift date has not been set yet.When the time comes I'll get with Mike and let everyone know.
Posted 24 July 2011 - 03:05 PM
Posted 24 July 2011 - 03:59 PM
Posted 24 July 2011 - 04:58 PM
Square Headlight Intense Team []lllllll[]
Posted 24 July 2011 - 05:39 PM
Posted 26 July 2011 - 10:58 AM
Posted 28 July 2011 - 08:00 PM
SOOOO,I'm starting Aug,8th, Mon. around 12:30 or so.everyday until every thing but the lift is done. If you can make it,cool, if not I understand.I'll do what I can as far as takeing pics.
If you still would like to help with the lift (at 4 wheel parts), when the time comes I'll post up when the date is set.
Posted 29 July 2011 - 11:01 AM
Posted 08 August 2011 - 06:24 PM
This is how it came boxed up
1, unplug the lights
2, unbolt the bumper
3,lower the bumper down and remove the clips that hold the wire loop for the lights
4, slide the bumper in place.I had a little trouble, the bumper was rubbing
A little BFH and the bumper went on
5, Install the 2 bolts & the 8 nuts & washer, tighten everything down
The one one other thing I did was use elect. tap to cover the plug for the lights for now
I think I'll do the sliders tomorrow. So if your free during the day and want to come by just let me know.
Posted 10 August 2011 - 09:43 AM
Btw, how heavy is that bumper
Posted 10 August 2011 - 10:49 AM
Posted 10 August 2011 - 11:18 AM
As always you need to remove the stock ones.I forgot to take a pic of how it looks but you'll see how to do it
1, lay out all your nuts, bolts, and washers.
2, there are 3 different brackets. The 2 that are square are for the front & middle. The other is for the rear.
3,On the front & middle you need to remove the u- nut and install the T- bolt. Just slide it in the hole.
4,The rear just bolts on.
The front & middle bracket.
5, Here you can see the 2 different size bolt holes on the weld seam.
6,Tighten everything down.
7, Hold up one end and install one of the bolts for the slider.
8, Do the same for the other 2 location.
9,Install the rest of the bolts and tighten each one to draw the slider in evenly.
10, Tighten everything up ( tight is tight enough )Go back later in a few days and re tighten everything.
Front
Rear
Posted 10 August 2011 - 06:22 PM
This is the skid, and the Evap.
There are 3 bolts and one you need to add
Remove the rear bolt, install the bracket, use the washer as a spacer for the other side.leave every thing loose for now
Remove the 2 bolts in the front and install the bracket. Again leave every thing loose.
Get your milk crate to hold up the skid to get some bolts started.
Go around and tighten every thing.
Posted 11 August 2011 - 11:35 PM
I think since the last time I saw you I've spent more time under Jeeps than over them lol. Been helping everyone I can just to try and learn.
2.5" OME Lift
Rubicon Express (pre 4wp) Track Bar in the front
OME Track Bar bracket in the rear
JKs Quick Disconnects
3"BL waiting to come off for my 1.25"BL
33x12.50R15 Mickey Thompson Baja Radial ATZ's
15x8 Cragar Soft 8's
Trail Gear front and rear bumpers.
Red LED interior lights.
Posted 17 August 2011 - 07:41 PM
Some of the pics did not load up, but I'll try to explain at that point.
1, Remove stock tire carrier and bumper, There are two bolts on each side of the frame rail and two behind the cross rail.
2, Lay out your bolts & washers
3, Remove the stock tow hook and install the backing plate in the left & right frame rails
4, Have your helper ( thanks guys ) hold up the bumper and install the 4 bolts through the bottom on the bumper, do not tighten yet
5, Install the 2 bolts on each side of the frame rail for the bumper. Once done level the bumper and tighten down all the bolts
Now its time for the tier carrier.
1, It helps to remove the rear right light so you don't damage it
2, Install the nylon washer, slide the tire carrier on the post,close the gate, add another washer,snap ring,install the two bolts
3, Install the handle assembly to the other end and bolt it down.
you might need to make a few adjustments to get the gate to close good .
With the tire on I can see its pushing tight agenst the carrier. Thats because of the back spacing of the rim. Some spacer should fix this
Posted 18 August 2011 - 05:30 AM
Posted 18 August 2011 - 06:40 AM
Is this the location of how it comes OEM or did you relocate
Posted 18 August 2011 - 10:13 AM
Thanks sunnyg8tr, I'm trying.
I need to do some things around here, when I'm done I'll check with Mike ( 4 wheel parts )
and see when he thinks we can do the lift there.
Posted 22 August 2011 - 08:29 AM
Oh well, were would 3rd party companies be if it was not for the bean counters and OEM mistakes.
Posted 22 August 2011 - 08:55 AM
Don't know about the 4 door JK's but Rich never hit the skid on his evap even though he hit every other part of the undercarriage up in WindRock
Posted 09 October 2011 - 04:51 PM
Rear
Frount
And the jeep on stock tires
I started around 9:00, by 5:00 I was driving down 75.NO shacks, no shimmy, no DW.Had the jeep up to 85mph ,,smooth.
Some time next week I'll have the 35"s on.
#25
Posted 09 October 2011 - 07:05 PM
#26
Posted 10 October 2011 - 06:37 AM
Are you going to keep the boot covers on the shocks
#27
Posted 10 October 2011 - 03:36 PM
I was in my garage all day Sat, it never did rain over here though,and when it did it was short lived. As for the shock boots I might keep them on. I never had a problem with them on my other jeeps, as long as they were on there tight.
#28
Posted 10 October 2011 - 04:49 PM
#29
Posted 10 October 2011 - 08:28 PM
#30
Posted 11 October 2011 - 02:33 PM
