Be the first to have the new water proof winch from Smittybilt. We just got our first X20 8,000lb winch in here at 4 Wheel Parts West Palm Beach. Headed down trail 3 in in the wet season? No problem. This winch can handle taking a swim and still pull you out at the end of the day.
The all new Smittybilt X2O 8 8,000 lb winch was developed for the hard core off roader that demands only the best. The X2O winch features our series wound amphibious technology which completely seals the 5.5 series wound motor as well as the three stage planetary gear system. It has an oversized, completely waterproof, state of the art 500-AMP solenoid that has the versatility to be mounted over the winch motor or winch cable. The control handle and hardware are manufactured out of marine grade stainless steel which will give a lifetime of service. Heavy duty rubberized remote control with a front end magnet which makes locating and controlling the hand held remote easier than ever. The new X2O 8 performance is as good as it gets.
Revolutionary planetary gear system boasts a 8,000 lb. line rating and 180:1 gear ratio
5.5 hp, 12-volt, Series Wound Motor
3/8" x 98.5' galvanized aircraft cable with replaceable hook included
Intuitive design ensures a simple, hassle-free installation
A heavy duty winching system with great features at an incredible overall value
Drum size: Diameter/Length: 2.5" (63.5 mm) x 8.82" (224 mm)
Mounting bolt pattern: 10" x 4.5" (4 bolts, 3/8") (254 mm x 114.3 mm)
Total shipping weight: 88 lbs
Includes Wired Remote Control, Roller Fairlead, and Hook
**Roller Fairlead Does Not Mount To Winch**
All Smittybilt Winches meet SAE-J706 standard ratings for winches
Water Proof Winch's are in Smittybilt X20 at 4Wheel Parts WPB
Posted 06 July 2011 - 09:19 AM
Most people aren't brave, they are just too stupid to realize what they are doing.
2006 Jeep Wrangler Unlimited Rubicon 4.0 with a 6 speed hand shaker: 4" Skyjacker lift, Super Lift bent Control Arms, High Rock front and rear bumpers, Rubicon Express Hand throttle ,Cragar 15" Soft 8's wrapped with 35" Dunlop Mud Rovers.
VP High Rollers Jeep Club
Posted 06 July 2011 - 10:44 AM
