U-POL Raptor spray in bed liner
Posted 02 June 2011 - 11:12 PM
so im getting the inside of my cj sandblasted on Thursday the 9th then the same day my new floor pans welded in and i just ordered the Raptor spray in bed liner so i will doing that maybe fri or Saturday morning anyone want to come help or just hang out and see how it works and looks.......
Posted 03 June 2011 - 07:36 AM
Several of us have sprayed it. Let us know if you have any questions, but I'm sure you'll be fine.
Posted 03 June 2011 - 08:25 AM
Posted 03 June 2011 - 08:57 AM
That's a preference, but I certainly would. Figure how far down you are and all the work that is in this. If you get rust in a few years and have to do it again, you'll be miffed. Before applying the bedliner, I sprayed the entire tub w/ 2 coats of MCU...all but guaranteed to be rust free for life.
On this job, I had the body off, which made it easier; but easily done w/ the body on as well
Shutz gun (dump gun, undercoating gun). The raptor bottles fit these guns fine and spray nicely.
Be sure to cork/tape/plug EVERY nut/insert/etc that you plan to reuse. If this stuff gets in the threads, it will be your nemesis...
I did the jambs and a few other areas also where body armor went on top...
HTH
HTH
Posted 03 June 2011 - 09:40 AM
what is MCU???????????
and what kind of primer should i use
Posted 03 June 2011 - 10:03 AM
MCU = Moisture Cured Urethane
MCU is the actual 'tougher than nails primer'...
I used a Pettit marine grade MCU
Some prefer POR15...
Neither of these are cheap (+/- $40/qt), but well worth it...
Posted 03 June 2011 - 10:48 AM
ok so after i put down some primer do i have to sand it all again?
Posted 03 June 2011 - 06:19 PM
What is the cheapest mcu to use.. Dont want to.break the bank....
Posted 04 June 2011 - 07:42 AM
I have no idea what the cheapest it. The one I use is 38.99/qt @ West Marine...1 qt will be plenty.
