Hey guys! I just purchased some 32" tires from discounttiredirect.com along with black cragar D windows to put on the TJ and I wanted to know if anyone knew of any places in the Gables/Miami/Kendall area that they would recommend to have them balanced and installed. I know there are a several places further north in the Ft.lauderdale area but i was hoping to not have to make the drive. I will if need be...Any help would be greatly appreciated.
Also, the tires and wheels are being shipped separately. Not sure how much of a difference that makes.
Thanks!
Local Area Tire Shops
Posted 24 March 2011 - 01:39 PM
2003 TJ-X, 4.0L, 5-speed...In the process of picking a much needed lift.
Posted 24 March 2011 - 02:16 PM
maybe alittle too far North but I have used Tire Country in Pompano and they really did a good job and have the bigger install, balance tooling to do it right without F-n up the rims and the do alignments on lifted trucks. There is usually 5 monster lift Jeeps and truck parked out front so you know they get this kind of business.
88 YJ "OLYMPIC" EDITION - 4.2, BA10, TrueTrac LSDs Front and Rear, Posilock, 4.10 gears, 4"RC Lift, 3"spacers, 2"shackles, GM HEI Dist, Motorcraft 2100 carb, SYE and Tom Woods CV drive shaft...
Posted 24 March 2011 - 02:26 PM
Call ROCO's at (305) 392-6808 and tell them that Trailabite sent you over. Ask for Rebeca!
Here's the address:
7448 NW 55 ST
Miami, FL 33166
Here's the address:
7448 NW 55 ST
Miami, FL 33166
Posted 24 March 2011 - 03:07 PM
I've always taken my tires and rims to the Martino Tire off of Miller and 137th. I drop them off and wait for the call to pick them up. Never had any issues. Becuase i install the set at home myself its real cheap. I think the last time i was told to give the tire guy $40 cash to mount and balance the set of four 35x12.50r15s.
BUILD IN PROCESS:
Posted 24 March 2011 - 03:21 PM
That's a good deal!
Posted 24 March 2011 - 05:04 PM
BlackOps: thats one of the places that i have heard from, distance is the only thing stopping me.lol
Thanks chuckie B!!
Trailblazer: That does sounds like a really good deal. Any idea how much they would charge to have the tires put on the wheels?
Thanks chuckie B!!
Posted 25 March 2011 - 07:16 AM
Don't know. Never actually done that.
I think the going rate at most places (because you're not buying it from them) is like $20 per tire/rim. The good thing is that with tire that size you should be able to take it anyplace.
BUILD IN PROCESS:
Posted 25 March 2011 - 08:07 AM
Oh ok...Thanks!
