U-joint strap bolt upgrade
Posted 13 February 2011 - 08:11 PM
You can see the strap bolt is broke inside the bottom right hole of the one on the left.
There are two FORD U bolt kits. Part # 81004 is an exact match.
I drilled the holes in the yoke w/ a 5/16" bit and installed the new strap bolts.
Posted 13 February 2011 - 08:56 PM
Posted 13 February 2011 - 11:17 PM
Posted 14 February 2011 - 12:54 AM
2006 Jeep Wrangler Unlimited Rubicon 4.0 with a 6 speed hand shaker: 4" Skyjacker lift, Super Lift bent Control Arms, High Rock front and rear bumpers, Rubicon Express Hand throttle ,Cragar 15" Soft 8's wrapped with 35" Dunlop Mud Rovers.
VP High Rollers Jeep Club
Posted 14 February 2011 - 07:44 AM
Posted 14 February 2011 - 09:14 AM
Read my signature defining experience.
Posted 14 February 2011 - 11:23 AM
Did u do the t-case as well
Posted 14 February 2011 - 11:38 AM
Posted 14 February 2011 - 11:40 AM
Posted 14 February 2011 - 01:52 PM
Rollbar, on 14 February 2011 - 11:38 AM, said:
WILLY.......................
Posted 27 February 2011 - 08:10 PM
Posted 27 February 2011 - 08:33 PM
CrackerJack, on 27 February 2011 - 08:10 PM, said:
Loose U-Joints/worn
left foot off the clutch and to much gas
wheel spin and grab
Posted 03 March 2011 - 08:44 AM
wheel spin and grab
You forgot to add lack of maintenance. I've notice that the squares usually don't do bolt checks, they just wait.
Posted 03 March 2011 - 11:43 AM
Jim B, on 03 March 2011 - 08:44 AM, said:
It may have been the U joints. It happened taking off from a green light in the morning. No wheel hop and no excessive skinny pedal (that time)
Posted 07 April 2011 - 11:53 PM
D-30; amc20; D-44?
Posted 08 April 2011 - 05:08 AM
Posted 08 April 2011 - 12:12 PM
I think you should get away from those U-Joints with ROUND.. bearing caps, I went back to the SQUARE ones and they have not failed yet..
Posted 08 April 2011 - 03:49 PM
Posted 08 April 2011 - 04:11 PM
Posted 08 April 2011 - 07:26 PM
JeepNWilly, on 08 April 2011 - 04:11 PM, said:
That's how driving w/ boggers feels!
Posted 09 April 2011 - 07:43 AM
wheel spin and grab
ignoring torque specs and overtightning bolts
