JEEPTALK.net: Towing w/ a Highlander? - JEEPTALK.net
#1 User is offline   Trailblazer
Posted 04 February 2011 - 12:56 PM
It's time to turn in the wife's lease and she likes the new Highlander. I was checking out the specs and it seams they've beafed it up a bit. Question is; do you all think this would be able to tow my jeep around? It's a YJ with tube fenders, comp-corner guards, full width axles and 38x14s, winch. Eventually it'll get a full cage.
V6 Toyota Highlander
3.5L DOHC - 270hp @6200 - 248lb ft @ 4700
Tow Package
5000-lb. towing capacity, 500lb tongue weight, HD radiator with engine oil cooler, 200-watt fan coupling, transmission oil cooler with water and air cooler, 150-amp alternator and prewired harness
BUILD IN PROCESS:
#2 User is offline   TallJeep
Posted 04 February 2011 - 01:19 PM
Do you want to flat-tow or are you gonna be using a trailer?? I don't see any issues at all if you flat tow but if you want to use a trailer i think it might be pushing it a little. Your jeep once you are done is going to be on the 4000 LB range right?? a decent trailer is going to be around 1500 LB, thats a bit over the towing capacity, maybe if you play around and get it perfectly balanced you'll be able to do it.
:2:
#3 User is offline   Trailblazer
Posted 04 February 2011 - 02:01 PM
It'll be flat towed for a while. Then eventually i might get a trailer. I might just have to settle for the Tundra :devilgrin:
My other dilema is that i plan to get either a popup or motorhome next year.
  • If i get get a popup i can tow it easier, it's cheaper and stores better. Downside is that i'd have to choose between towing the popup or the jeep.
  • An rv is a lot more money and harder to store but i can easily tow the jeep anywhere.
The other option would be two buy a longer flatbed and tow the popup and jeep on it. Downside to that is storing that long trailer.
BUILD IN PROCESS:
#4 User is offline   92SquareEye
  • Gender:Not Telling
Posted 04 February 2011 - 02:11 PM
I trailer tow with a Chevy Trailblazer. It has the 4.2 inline 6, which is making 275 horsepower at 6,000 rpm and 275 ft-lbs. of torque at 3,800 rpm. It's rated to tow 6300 pounds. Honestly, it's not the ideal towing solution, but it works just fine. If i drive slow enough, I can squeak 13-14 mpg out of it...@ 70, I'm getting 10. I've trailered the Jeep to TN, GA 3x and numerous times to Ocala and mid-Florida. It has coil springs in the rear which causes it to sway more than w/ leafs, but I added a set of air bags in the rear and an anti-sway control bar and its much better now. Also added a brake controller for using the trailer brakes which made a huge difference...
#5 User is offline   Jim B
Posted 04 February 2011 - 02:45 PM
What about a Toyota Sequoia :question:
#6 User is offline   MilesAway
  • Sergeant Major
Posted 06 February 2011 - 05:51 PM
If you go for the tundra or the sequoia make sure to cary extra gas on the trailer. I have a tundra and had to install a 46 gal tank in it, as it only gets about 8 mpg. Just spring for the motor home that way the fuel is the same and you get the larger tank from the get go and if you run out of gas atleast you will have your bed with you
