is tonight towershops
Posted 14 January 2005 - 09:41 AM
Posted 14 January 2005 - 09:49 AM
2004 TJ X
2.5 RANCHO Lift
R.E. Quick Disco's
TxT Front Bumper
Jeeperman Rails/Steps
M/T 33x12.50
(OIIIIIIIO)
Offroad Technology rear bumper and tire carrier
Posted 14 January 2005 - 10:43 AM
Posted 14 January 2005 - 10:47 AM
Posted 14 January 2005 - 03:04 PM
'98 Grand Cherokee
Ru•bi•con n.
Posted 14 January 2005 - 04:45 PM
#7 Guest_Livefree_*
Posted 14 January 2005 - 06:21 PM
Posted 15 January 2005 - 09:01 AM
One highlight was Seans RC Jeep... 1/18 scale(I believe), very realistic looking, although electric, has sounds like starting the engine, engine running, horn, full lighting to include turn signals (Jack remarked that it was probably the only vehicle in Florida that used turn-signals reguarly). It also had 2 wheel drive but high/low transfer and 3 gears in each....
It needs a bumper sticker, however. I like the one I saw in Port Charlotte last weekend that said: " A penny for your thoughts" -- " A dollar if you flash me".
The other highlight was Ruben's X-Jeep.... as in one he once owned but sold to a friend in Miami. He showed off the roof-rack complete with rear stairs.
He says he will be making them again along with rear bumper-tire carrier.
joe
DAYTONA BEER POLICE MEMBER #6
'04Liberty--3.7L, auto, 4x4
Joe
Posted 15 January 2005 - 11:48 AM
sky6, on Jan 15 2005, 09:01 AM, said:
$2 if you look good.
I tried to make it but the War Dept had plans. Ruben's rack design is the best "I've ever" seen. I had one a while back and 3 years ago when I rolled in Moab end over end it saved me from a lot of damage. Needles to say that the rack was toast but I was able to continue wheeling. One of the reasons that I got back and had another person build be the exo I have now because Ruben had stopped doing them.
#10 Guest_Livefree_*
Posted 15 January 2005 - 06:46 PM
