Flat Towing YJ by front shackles is it possible?
Posted 03 September 2010 - 12:29 PM
I saw "towing shackles" I think on Ebay. They are designed to replace your existing shackles and have a third hole to allow the connection af a tow bar. they are triangle shaped so the the "towing hole" is slightly forward of the frame mount and the spring eye. Any ever use them? Is it a good idea to drag a YJ by its shackles?
I have boomerang shackles and I was thinking that I could attach the tow bar to the center hole in much the same way. Any ideas?
Captnrich
93 YJ 4.0 L Pretty close to stock, 31x10.5 tires, 2" lift, 1.5" Boom Shacks.
30' Century "Miss Tori II"
Commodore, Sink 'Em & Drink 'Em Yacht Club
"If you can't fix it with a hammer, it's an electrical problem."
"No matter how bad your day has been, remember this:
somewhere, out there, there is a Mr. Pelosi."
Posted 10 September 2010 - 10:02 PM
Better to be safe than sorry. I would tow the jeep on a 5k trailer with air brakes.
Posted 11 September 2010 - 07:57 PM
hmmm....seems you're forgetting about the paper thin shackle mount that is welded to the frame. i have ripped those off on multiple yj's out on the trail. just cuz the shackle is upgraded, don't overlook the "weakest link".
not a good idea in my opinion.
2006 Rubicon Unlimited
1987 Wrangler--Barbie Jeep
1983 Scrambler--Rubi's Daddy
Posted 14 September 2010 - 10:52 AM
Ahh.... That's why I asked!
I am having some custom tow bar / recovery points welded up. I just thought the shackle idea was interesting.
Captnrich
Posted 14 September 2010 - 02:53 PM
That's what I did, Rich. I have 1" thick clevis tabs thru-welded in my bumper with 1" diameter holes in them. I had a local shop make me new mounts for the tow bar to go over the tabs, then I slide 1" roundbar through the hole and secure w/ pins.
PS - Try to devise a set-up that only you can use. Otherwise, it gets borrowed more than it gets used...
Posted 15 September 2010 - 11:51 AM
Thanks, guys. Build a one off system....I like it.
Captnrich
Posted 15 September 2010 - 12:01 PM
Posted 16 September 2010 - 08:47 AM
One thing a lot of people don't know about when flat towing is many states including Florida that the brakes on towed vehicle need to be connected to towing vehicle.
http://www.readybrak...state_laws.html
87 GRAND WAGONEER "Choptop Waggy" , 35" BFG m/t,
3" body lift, SOA/shackle flip, PRO COMP SHOCKS, C/B, TJ rollcage "modified", Edlebrock 4bbl offroad carb, HEI Dist and Lockrights front and rear.
Orlando Jeep Club
If parts ain't flyin, you ain't tryin !!
Orlando Jeep Club
