Re-winding your winch cable
Posted 27 December 2004 - 08:49 AM
I have an auto, so what's the best way to rewind the cable after I check it and determine whether or not it needs a new one. Can I do this myself or do I need another set of hands?
Any input appreciated
Posted 27 December 2004 - 09:00 AM
Find a sloped street/parking lot (one that's not used ).
Hook the cable to a strap around the pole/post and put the winch in neutral. back up until the cable is unwound.
Check the cable/drum.
If all is OK, put the trans in neutral and winch the cable back in w/ the second person helping to guide the cable.
Posted 27 December 2004 - 09:31 AM
Bad news on the 4 hands, but makes sense. Hope it works, it looks good but it hasen't been used in about 2 years.....better to find out now than when I need it right :jump:
Posted 27 December 2004 - 09:38 AM
BE SURE TO HAVE THE HELPER WEAR LEATHER GLOVES!
SFJC, Jeep Club Advisor
Posted 27 December 2004 - 10:01 AM
make sure you tell your helper to keep his fingers far from the winch. since most people never used one before....
Posted 27 December 2004 - 11:44 AM
Park about 100 feet from you favorite pole, take out the line hook to the pole with a tree saver, come back to vehicle, see how much you have left on the spool, back up until there are about 5 loops. Vehicle in neutral, hook up the winch controller, start to winch slow while you guide (use gloves, not too close), if the vehicle start to head the wrong way, stop, turn the steering wheel to do the minor correction, come back to the front & keep winching and checking the cable.
If you are in the flats try to engage a bit of tension, slightly engage your ebrake to the point that the vehicle still moves. This has worked for me for years. Btw, make sure the winch control cable is out of the way do you don't run over it... been there.
Posted 27 December 2004 - 02:02 PM
So I'll hook her up to the tree tomorrow and go slow, should be OK
Posted 27 December 2004 - 05:57 PM
1. When hooking to the pole(S), place the strap low to the groung so the pole won't come over due to the past storms some poles maybe cracked etc. better yet hook to a big tree.
2. Put the emergency brake on part way to add some tension to tighten the cable up. You will use more brakes just stopping @ a light than it will use applying the e-brake.
Just a thought,
Posted 28 December 2004 - 09:00 AM
thanks guys oh, and I kinda figured the strongest part of the tree no matter what is low on the trunk. :sneak:
Posted 28 December 2004 - 09:08 AM
If you just purchased a brand new winch or a new cable... it must be stretched tight. It does not come this way from the factory and I belive the user's manual mentions to do this. Unwind all the cable and use the find a pole technique.
Why do we do this... anyone
Posted 28 December 2004 - 09:17 AM
1, it tightens the cable on the drum, the manufacturers wind the cable at high speed and cannot put the needed tension on it.
2, due to the low tension on the cable for the factory, if it is not stretched, the windings may not be uniform and the cable will want to bunch up and act like a birds nest.
Posted 28 December 2004 - 10:39 AM
Another thing we did was loom the cable coming through the grill to keep the cables from rubbing and eventually shorting out as it rubs on the grill (or anything else). I need to double check this, since it seems some of the loom isn't where I remember it, but my memory ain't what it used to be. On this Jeep it looks like I may be better running right under the grill. The AC hard lines are in a different place on this one so I gotta look further.
Posted 28 December 2004 - 01:51 PM
Jim B, on Dec 28 2004, 09:08 AM, said:
Well some cables that come with the winch arent attached to the drum.
'98 Grand Cherokee
Ru•bi•con n.
Posted 29 December 2004 - 09:06 AM
