1987 CJ-YJ-TJ-7 (MUTT) Build Up
#31
Posted 16 August 2010 - 05:22 PM
#32
Posted 17 August 2010 - 07:46 PM
CaptainCody, on Aug 16 2010, 06:18 PM, said:
Rollbar, on Aug 16 2010, 06:22 PM, said:
Thank you! working on more
1987 YJ7TJ
That's all folks!
#33
Posted 17 August 2010 - 08:08 PM
These bulbs I will re-use later on...
I will cut off and re-use these harnesses later...
Uh Huh - Oh Yeah - Who's the woMAN!
Putting lights together / change out wire harnesses / self make grounding / etc. - next.
1987 YJ7TJ
That's all folks!
#34
Posted 17 August 2010 - 10:49 PM
http://www.myjeepspace.com/RickM610
My Jeep (JK BEAST) on Facebook
#35
Posted 18 August 2010 - 04:39 PM
License plate now goes in the middle (when I install my custom made license plate holder), and a plate light on each side evens the look out. Had to go with on-the-side method because no room for on-the-top method.
1987 YJ7TJ
That's all folks!
#36
Posted 18 August 2010 - 04:57 PM
#37
Posted 18 August 2010 - 06:11 PM
Still going...
1987 YJ7TJ
That's all folks!
#38
Posted 18 August 2010 - 07:19 PM
#39
Posted 18 March 2011 - 06:37 PM
LrdJeffson, on 18 August 2010 - 07:19 PM, said:
Watch out buddie! Actually you may be right if I don't start feeling better. I may have to join another club!
1987 YJ7TJ
That's all folks!
#40
Posted 18 March 2011 - 06:42 PM
1987 YJ7TJ
That's all folks!
#42
Posted 19 March 2011 - 07:36 AM
TranyDoctor, on 18 March 2011 - 08:32 PM, said:
BUMPED 3...The camera man has a short memory
1987 YJ7TJ
That's all folks!
#43
Posted 19 March 2011 - 08:56 AM
Adding pics to this:
1987 YJ7TJ
That's all folks!
#44
Posted 22 March 2011 - 07:09 PM
1987 YJ7TJ
That's all folks!
#45
Posted 22 March 2011 - 07:47 PM
#46
Posted 22 March 2011 - 08:56 PM
#47
Posted 23 March 2011 - 04:52 AM
#49
Posted 24 March 2011 - 08:14 PM
Another weekend in the neighborhood...
Shot of a new trick? Ewww Laaa Laaa - I like the teacher! OK OK I'm do'in the teacher!
Works pretty good!
I really love this tool!
YeeHee
HE'S SO SWEEET!
Next...my awesome blow errrrr paint job!
1987 YJ7TJ
That's all folks!
#50
Posted 24 March 2011 - 08:54 PM
#51
Posted 25 March 2011 - 10:50 AM
Gutsy, on 24 March 2011 - 08:14 PM, said:
Exceptional job! I'm also glad you were referring to the engine.
Let's see that paint job!
#52
Posted 25 March 2011 - 11:07 AM
#53
Posted 25 March 2011 - 05:33 PM
My (sometimes) better 1/2 (when he doesn't doubt me ) helped me tremendously with this job. He was definately ... thought I was
But I bought the colors I wanted and went with the pattern I wanted anyway! This was in my head long before I had a jeep. When a woman sees in her mind what she wants...she knows and she gets it!
The lighting is poor on these shots. Some are at night in a shop with not-so-good lighting, and some are in direct sun.
The real beauty is when you see it in person!!! 3 colors. The charcoal and the silver are metallic.
He was definately by this time....
Will show the final job later. Now HE is bragging it's so cool. It says BAD A$* jeep, with a little SHE in it!
1987 YJ7TJ
That's all folks!
#54
Posted 25 March 2011 - 07:20 PM
Square Headlight Intense Team []lllllll[]
#55
Posted 25 March 2011 - 08:37 PM
#56
Posted 25 March 2011 - 08:56 PM
nice work. does it have a clear coat too?
#57
Posted 25 March 2011 - 10:26 PM
99 TJ - Wrangler Sport
#58
Posted 26 March 2011 - 06:55 AM
I can see Trany driving it on the road so tell him to keep away from it.
Can you give us a bit more detail on the steps you took on laying down the 3 colors
#60
Posted 26 March 2011 - 10:02 AM
Yes clear coated it - 3 layers. It has some blemishes...it's not a professional paint job by far, and not done in a normal painting booth but what the hey, it's home grown And down here, it's always gonna have a little dirt and mud on it.
We winged it per say and were in a hurry. Painted entire jeep with the charcoal gray metallic and let it dry. Then taped the first pattern where I wanted the silver metallic, and then taped paper over the charcoaled sections. Then painted the exposed sections with the silver metallic. Let dry for a while, then taped the pattern where I wanted the pink and then taped paper over the silver sections. Then painted the pink areas. Let that dry for a while, then hit it with the clear. Only got one small run and that was with the clear. It came out great!
In person you can see the little flecks of color in the charcoal and silver sections...the flecks have some torqoise/green colors, blues, you can even pick up some pinks. It's awesome.
Ideally, if I had a booth and all the time in the world...I would have marked the entire pattern and would not have overlapped the paints. I would have papered, etc. and butted the colors right up next to each other. I would have also let each color dry a lot longer as well.
The wells, bumpers, rollbar, etc. will be the rouch black I painted under the hood. The inside of the jeep, after sand-blasted and primed, will be the charcoal metallic thicken up to make it a little rough as well, unless I use the same color I used on the motor. I was thinking about going with the silver for inside because it would be cooler to the touch, but it's blinding bright in the sun.
Definately a fun project. We really had no clue how it was going to turn out. We figured what the heck, we had plenty of the charcoal to re-do. At least that's what HE kept saying
1987 YJ7TJ
That's all folks!
