Flat tow question
Posted 05 February 2010 - 12:10 PM
Posted 05 February 2010 - 12:23 PM
i always put the transfercase in neutral , then put it in 1st gear, then i pull the jeep with my hands to the tow vehicle hitch. that guarentees its truly in nuetral...
is your jeep auto?
Posted 05 February 2010 - 01:13 PM
Rambo, on Feb 5 2010, 12:23 PM, said:
I plan to do the same when the jeep is done, but why would you leave an auto tranny in park?
Posted 05 February 2010 - 05:18 PM
Posted 05 February 2010 - 11:48 PM
Posted 07 February 2010 - 06:24 PM
Posted 07 February 2010 - 06:31 PM
Posted 07 February 2010 - 07:05 PM
Posted 07 February 2010 - 07:15 PM
Posted 29 April 2010 - 09:22 PM
I'm sure its in their, maybe you just missed it.
Posted 02 May 2010 - 12:05 AM
Posted 11 January 2011 - 07:14 PM
trailblazer, on 05 February 2010 - 01:13 PM, said:
Rambo, on 05 February 2010 - 01:34 PM, said:
Both the automatic & the manual transmissions are left in a locked state by leaving it in "PARK" (auto) or in gear (manual) for the same reason. Even with the T-case in neutral the T-case input shaft will want to spin a little while the output shaft is being turned by the rolling wheels, leaving the transmission locked in park or gear will prevent this.
Imagine 2 desk fans facing each other. One is plugged in & powered up (think wheels turning driveshafts/T-case output shaft) while the other fan remains unplugged (think T-case input shaft & transmission output shaft) or turned off. The air from the powered fan will spin the unpowered fan, and the same thing will happen in the T-case with regards to the input & output shafts unless the transmission is locked.
If this is allowed to happen by leaving the transmission in neutral, the transmission will not have the benefit of recieving bearing lubrication which is normally provided by the front pump being turned in an automatic or the cluster gear shaft spinning in a manual transmission with the engine running.
For flat towing, T-case in neutral, transmission in park or locked in gear. Hope this helps!
Max
Posted 11 January 2011 - 07:23 PM
