OK, what is the difference and why?
1. CD-R
2. DVD R-
3. DVD R+
Signed,
New tech for burning multiple CD/DVD in the same drive at once
CD-R/DVD-+-R/DVD-R
Posted 04 February 2010 - 01:50 PM
Posted 04 February 2010 - 09:31 PM
CD-R is the standard writeable CD's Music or Data. 80 Minutes or 700 MB
DVD-R is a recordable format of DVD's typically has a storage capacity of 4.71 GB
DVD+R is different recordable format of DVD's typically has a storage capacity of 4.71 GB
The DVD+R is newer that the DVD-R and get you basically the same result but they are not interchangeable.
Found this at a website
A DVD-R is a write-once format: once you've burned the data onto that DVD platter, the disk is forever frozen with that information. Add the "W" to that, and you'll find that DVD-RW can be erased or rewritten up to a thousand times. Seems kinda weird, but if you can do so, DVD-RW obviously has significant advantages over DVD-R. DVD-RAM was even more flexible, however, since it let you erase and rewrite sections of an existing DVD, something that you cannot do with DVD-RW.
Moving to the plus side is where things get a bit confusing, because DVD+RW came before DVD+R. The plus formats have the same data
storage capacity
as the minus formats (4.7GB), but DVD+RW offers faster writing, better internal linking (a technical obscurity you don't have to worry about), and support for drag-and-drop desktop files, which makes it easy to compose the contents of a disk. DVD+R is a write-once format intended to be more compatible with more DVD players, though at this point it seems to be about even with DVD-R, which remains the most compatible computer-burned DVD format.
storage capacity
