OK, so I pushed the small pin on the back of my D-link router and everything for a while, thought I would never get back but I did. Since that time I tried to put the OPEN/WEP on my two computers but when I do it will not recieve a signal. What's up ?
WEP - WEP2a Security
Posted 30 January 2010 - 02:39 AM
One thing to try that I can think of right off. Go to start then control panel. Then network connections. open it then right click on local area connection. then properties. Check the conect using at the top. there is also a configure next to it to aid in the conection. this should help the PC find and conect to the router. But there are many reasons this can happen.
John
Member of:
Member of:
Posted 30 January 2010 - 09:00 AM
Did you set up your router first with the WEP password
When your computers sees the wifi and you say connect it should pop up the screen for you to put on the same WEP key you set up on the router. You must set up the router first though.
Posted 30 January 2010 - 10:10 PM
Oh, I guess i should check into that. Look West young man to the mushroom cloud in the sky
