Wifi Router Signal Boost
#61
Posted 29 March 2011 - 07:20 PM
2. Yes it needs to be wired using the ethernet cable and should be configured as an accesspoint only.
3. no need to answer this one since the answer above is Yes
4. You'r Welcome!
#62
Posted 29 March 2011 - 07:40 PM
We will see what happens on Thursday as to their wireless router, then I will need help on the access point set up.
#63
#64
Posted 29 March 2011 - 07:45 PM
I guess I'll have to find a place that sells Ethernet cbl in length to the access point, or get a beam dish
#65
Posted 29 March 2011 - 07:50 PM
Do you get Wifi signal at all at the house?
#66
Posted 29 March 2011 - 07:59 PM
Not sure if their router will reach or not, that is why I was thinking of something to get it there better. Better than paying for extra service @ the office.
But I do have a small antenna @ the office and from what I have read, they need to be able to talk to each other, meaning, even though you have a good output from a base station, you still need something to send it back.
Not sure what they have as a router.
Here is what I have @ the office,a 2dbi but now I found out they have 5dbi:
http://www.compusa.com/applications/Search...&CatId=2688
#67
#68
Posted 29 March 2011 - 08:25 PM
Jim II
#69
Posted 29 March 2011 - 08:28 PM
I wonder if it can be placed at the office and have enough powere to pick up the signal from the house or at worst case build a small building like a doghouse somewhere equal distance from the house and office and place it there.
#70
Posted 29 March 2011 - 09:41 PM
Hum, let's see what charter does and then I will look into this w/a report back.
In the buildings window, it would be 200' away from the house and 28' from the office, might work.
#71
Posted 29 March 2011 - 09:52 PM
#72
Posted 31 March 2011 - 01:47 PM
Does one have to go into the D-link settings?
Will the routers conflict or be compatible since the driving router is giving the accessory router the same signal.
#73
Posted 31 March 2011 - 01:52 PM
#74
Posted 31 March 2011 - 01:57 PM
Thanks will check it out.
?~Will this boost my signal or are they only putting out the same individually just being separate antennas.
?~Will this make a bigger field of antenna range, meaning broadcast but same power, just better field to pull from.
What if it's 3' away for testing?
#75
Posted 31 March 2011 - 02:01 PM
You could have 2 routers in line but things can get a bit complex so it is better to make the D-Link an Access Point only device.
What is the exact model and revision of the D-Link? It should have that info in the back or bottom of it.
example:
DIR-615
DIR-615_REVB
DIR-615_REVC
DIR-615_REVE
#76
Posted 31 March 2011 - 02:11 PM
Rollbar, on 13 September 2010 - 10:40 AM, said:
I have to look what router they gave me, looks sweet though.
Yes access point only but if it's not going to do much I might as well move the antenna @ the office to the end of the building but then I would have to get a 36' USB cable M/F.
On the second page I listed the D-Link 615 but would have to check if there are any numbers after it.
I might just have to save and get the repeater you mentioned, plug-n-play and put if @ a window in the church and let it beam to the office 35' away.
#77
#78
Posted 31 March 2011 - 02:16 PM
That would put the antenna closer. It use to be in the bedroom window, but now I had them move it to the family room window so Jr. & I could run hard lines to the X-Boa/Laptop and get 36meg +. W/out the hard line I was getting 19-22megs.
Speed man, speed!
#79
Posted 31 March 2011 - 02:21 PM
#80
Posted 31 March 2011 - 02:23 PM
#81
Posted 31 March 2011 - 02:24 PM
#82
Posted 31 March 2011 - 02:26 PM
Got to check on the cable, I think I listed one on page one, have to look.
#83
Posted 31 March 2011 - 02:33 PM
JeepNWilly, on 24 August 2010 - 01:58 PM, said:
5 Meter extension cable
http://www.amazon.com/Low-loss-Antenna-Ext...r/dp/B003FQZNXA
30 Feet Extension cable
http://www.gadgettown.com/30-Feet-Antenna-...ble-Router.html
The 30' looks better, ordering it now.
#84
Posted 31 March 2011 - 02:37 PM
#85
Posted 31 March 2011 - 02:39 PM
7 bucks, if not I will send back (free shipping) or send it to you
#86
#87
Posted 31 March 2011 - 02:55 PM
I'm connected @ 14.5Mbps it says but my speed test differ some.
Speedtest.net
2.15/1.95 was 6mbps/10mbps w/the D-link on the bedroom window but I think if I can get my antenna closer it would be fine for what I need @ the office. I just wish HIRO offered the 5dbi antenna when I bought the 2dbi. Oh well, at least I will be smoking @ home w/min 25mbps and about 36-45 hard lined in
Ok, going home for lunch.
#88
#89
Posted 31 March 2011 - 02:58 PM
#90
Posted 06 April 2011 - 06:09 PM
JeepNWilly, on 29 March 2011 - 08:03 PM, said:
OK, I checked the second picture from CompUSA and it has a rating of 3dbi. I have a 2bdi antenna now @ the building. I don't see where this would be any advantage.
example:
DIR-615
DIR-615_REVB
DIR-615_REVC
DIR-615_REVE
I have the DIR-615 D-Link.
Rollbar, on 31 March 2011 - 02:33 PM, said:
I received the 30' cbl and it did not work, seems it couldn't push the length.
