Jim B, on Aug 23 2010, 05:20 AM, said:
If so, just set up an amplified access point near your wifi router and you will be able to receive signal for 1+ miles. I have an old one in a box and a new one that I'm using now that works great as I had problems going from one end to the other through the walls and second floor. My neighbor is an acre away tells me that he gets better signal from mine than his (except he can't connect to mine ).
That would work Jim, LINK?
I have 42% signal but there are days where it drops to 8%/26% etc. depending on the weather/heat. I'm pretty far away and I got (7mos ago) NetGear Range Router, works ok (D-Link is better IMHO). I just need a boost.
JeepNWilly, on Aug 23 2010, 05:45 AM, said:
Willy, thanks but I can't use that on my WIN7 @ the office. Plus, I need everything inside except the cable due to the cold/snow/moisture.
Thanks guys,
