JEEPTALK.net: Wifi Router Signal Boost - JEEPTALK.net
  • 5 Pages +
  • « First
  • 3
  • 4
  • 5
#121 User is offline   JeepNWilly
  • Brigadier General
Posted 29 April 2011 - 09:29 PM
:2thumup:
Willy
Keep Calm And Wave On
Pics:
#122 User is offline   Rollbar
Posted 29 April 2011 - 09:30 PM
I'm gonna put the switch in the garage, then push to the office.
#123 User is offline   Jim B
Posted 02 May 2011 - 07:01 AM
Ok I'll bite. What caused your decision to finally decide to bury cable :question:
#124 User is offline   Rollbar
Posted 02 May 2011 - 03:30 PM
Needing two access points that range from 200 bucks a pop to 1200 a pop.
Plus the kids are here and they can help :rof:
The real reason, NO TECH SUPPORT from the EAST :whistle: :nervous: :amazed: :sos:
#125 User is offline   JeepNWilly
  • Brigadier General
Posted 02 May 2011 - 04:18 PM
No tech support huh :bat:
Willy
Pics:
#126 User is offline   Rollbar
Posted 02 May 2011 - 04:49 PM
Inside joke w/Jim B :empathy:
#127 User is offline   Rollbar
Posted 09 March 2012 - 02:03 AM
OK, cable in, Switch in, PC finally has internet in the office.
Not I want to put my D-Link 615 in the office so I can have WiFi when needed around the building.
Can I just hook it up in the office and run the PC off that? OR will it conflict w/the wireless router in the house.
I do have some signal at the office sometimes but it is not enough for internet connection unless it is JT or CJO.
#128 User is offline   JeepNWilly
  • Brigadier General
Posted 09 March 2012 - 08:29 AM
Is your D-Link 615 a router?
If it is a router then you can't unless you turn off the router and make it as an access-point only.
I have my Belking setup that way.
Willy
Pics:
#129 User is offline   Rollbar
Posted 09 March 2012 - 01:16 PM
You can use the second router at the other end, but you will need to subnet it. Your first router is 192.168.1.1 on the LAN side, then make the second router 192.168.2.1 for the LAN side. Only issue with this is you will not be able to share printers or files folders with the computers on different subnets,
Can I do this?
IF so, then how do I do it--meaning, do I plug in the router (D-Link) at the office and configure or ..
#130 User is offline   JeepNWilly
  • Brigadier General
Posted 09 March 2012 - 01:19 PM
I have to look at the D-Link manual to see.
So you have a hard-wire Cat5 cable from the house to the office right?
Then you have a Network Switch at the office where you have the PC Plugged it?
If not explain the setup you currently have.
Willy
Pics:
#131 User is offline   Rollbar
Posted 09 March 2012 - 01:23 PM
Hard wire from House router to Garage (Pics on page 3 or 4 I think) switch,
Garage switch to Office PC,
Wired to PC from garage.
I was told to put the switch in the garage to boost the signal to the length of the cable to the office and it is working fine.
#132 User is offline   JeepNWilly
  • Brigadier General
Posted 09 March 2012 - 01:34 PM
You can add an access-point to the office connected to the wire from the garage.
I will need to look at the D-Link's manual to see if it can be set as an access-point only.
Willy
Pics:
#133 User is offline   Rollbar
Posted 09 March 2012 - 01:39 PM
Ok thanks. In this post I have my info on the D-Link.
#134 User is offline   Rollbar
Posted 09 March 2012 - 02:08 PM
http://apttech.wordp...an-access-point
Is this it Willy?
#135 User is offline   JeepNWilly
  • Brigadier General
Posted 09 March 2012 - 02:11 PM
yes
Willy
Pics:
#136 User is offline   Rollbar
Posted 09 March 2012 - 02:34 PM
Thanks, I think I did it. Now to take it to the office and see if I have WiFi.
Will advise.
Jim
#137 User is offline   Rollbar
Posted 09 March 2012 - 03:23 PM
OK, I'm at the office and I can't get the WiFi to work.
I followed all the steps but nadda
Office PC is hooked to the router and I'm on the net. Just can't get WiFi even though the WiFi light is on.
#138 User is offline   Rollbar
Posted 09 March 2012 - 03:42 PM
View PostRollbar, on 09 March 2012 - 02:08 PM, said:
I don't fully understand step 5.
I entered 192.168.0.2
Now the subnet is 255.255.255.0 / I changed the last number to a 1, then a 2 etc but it would not take it, so I put it back to .o
I set the WiFi password and saved etc but I can't get WiFi on my iPhone after iPhone reboot.
#139 User is offline   Rollbar
Posted 09 March 2012 - 03:49 PM
GOT IT WILLY!!!!!!!!!!!
Thank you, :blowup:
#140 User is offline   JeepNWilly
  • Brigadier General
Posted 09 March 2012 - 04:35 PM
The IP needs to be the same as you network IP because your main router ar the house is the one handing out the IP addresses via DHCP
The Subnet needs to stay 255.255.255.0
Willy
Pics:
#141 User is offline   Rollbar
Posted 09 March 2012 - 05:37 PM
Ya disabled UnPn and the IP thing. Made the router 192.168.0.2 instead of .1
#142 User is offline   JeepNWilly
  • Brigadier General
Posted 09 March 2012 - 05:38 PM
:2thumup: you are learning fast
Willy
Pics:
  • 5 Pages +
  • « First
  • 3
  • 4
  • 5
Fast Reply
