YJ Vacuum Disconnect Bypass
Posted 15 January 2010 - 05:21 PM
Posted 15 January 2010 - 05:26 PM
Posted 15 January 2010 - 08:00 PM
floppy, on Jan 15 2010, 05:26 PM, said:
I jumped on the palmetto & did 55. There was some vibration but not too bad. For me this is just a temp solution so I can start going on some wheeling trips. Hoping I can find a good deal on a posi-lok or maybe I can get w/ you & check out your setup for the long haul.
Posted 15 January 2010 - 08:11 PM
i used the cable on my jeep cause it was a diesel with no vacuum. also installed a few for customers. its ok but personally i like the vacuum better.
if you need info let me know
Posted 16 January 2010 - 10:05 AM
Posted 16 January 2010 - 06:48 PM
2003 Dodge Ram Quad Cab
Member: Square Headlight Intense Team
Always looking to get dirty…
…daddy to be... 8/27/10
"If you don't stand behind our troops, please feel free to stand in front of them"
"Dont quote me on anything i say from knowledge.. only experience"
Posted 17 January 2010 - 04:37 PM
Posted 18 January 2010 - 09:54 AM
Posted 18 January 2010 - 07:25 PM
Brian- the more I drove the jeep, the more the vibration started to bother me. I don't know how much balancing the front driveshaft would reduce this but you should look into it before spending the time to bypass it & wind up unhappy at the end.
Posted 18 January 2010 - 07:47 PM
Posted 18 January 2010 - 07:54 PM
Posted 18 January 2010 - 08:11 PM
Posted 18 January 2010 - 09:01 PM
LrdJeffson, on Jan 18 2010, 07:54 PM, said:
Don't take it personal. The man does go by "doctor"!!
Posted 24 January 2010 - 01:25 PM
Posted 24 January 2010 - 01:32 PM
Posted 08 March 2010 - 10:14 PM
Posted 08 March 2010 - 10:50 PM
Posted 09 March 2010 - 10:34 AM
I was worried about the drive home whn I was flat towing it. I guess my front DS is balanced pretty good. Was going 65 an I didn't noticed any vibration from the towing vehicle. Also, I'm lucky to go 60 downhill driving the YJ. Hah
Posted 09 March 2010 - 10:47 AM
Posted 09 March 2010 - 11:42 AM
Seems you wil do DAMAGE DAMAGE DAMAGE but what do I know?
Posted 09 March 2010 - 12:18 PM
Posted 09 March 2010 - 01:20 PM
never thought of that. good info, thanks. but say I was to put in a TJ shaft or similar (one piece) I would have the same problem then wouldn't i? why is this a known upgrade? your probably right, never thought of that but now I am confused. it would be the exact same issues with the diff with it locked and only have to put it in 4wd to engage it.
dave, I see what your saying about the 2wd fun. but if I do not engage it and only leave it in 2wd, wouldn't only the rear spin? obviously if I have 4lo or 4hi engaged it would turn the fronts…. ???
Posted 09 March 2010 - 03:22 PM
#25
Posted 09 March 2010 - 03:27 PM
CrackerJack, on Mar 9 2010, 03:22 PM, said:
as long as we are on the same page and I wasnt missing anything.
off topic, Jack did you get those pics sent to my server yet?
#26
Posted 15 February 2011 - 11:36 AM
#27
Posted 24 February 2011 - 09:41 AM
#28
Posted 24 February 2011 - 11:37 AM
#29
Posted 24 February 2011 - 01:14 PM
