JEEPTALK.net: Can you ID an axle this way? - JEEPTALK.net
#1 User is offline   Rollbar
  Posted 30 June 2003 - 09:40 PM
Can you ID/see the mfg's name or numbers of the axle if you take the D-cover off. :toilet:
It's been awhile. :2thumup:
Posted Image™ <----CLICK
#2 User is offline   Jim B
  Posted 01 July 2003 - 08:59 AM
Rollbar,
I don't think so, could be wrong but I've never seen it.
Here is a link that will identify most. Hope it helps. :2thumup:
Axle Identification
#3 User is offline   Rollbar
Posted 01 July 2003 - 09:27 PM
Thanks Jim,
That will work for the future.
What I was really after was the punch marks/ID marks on the axle shaft it's self.
Just wondering no biggie, I just didn't want to pull the axles out to see if it was a two piece etc. I was thinking that the 20axle I have may have been changed out to a one piece
#4 User is offline   Jim B
  Posted 02 July 2003 - 06:54 AM
Rollbar,
Go to the airport and put the housing through the xray machine. :microwave: :angry1:
:toilet: :2thumup: :dribble:
#5 User is offline   jeepincj78
  • Brigadier General
Posted 02 July 2003 - 07:35 PM
If you are talking about a model 20 rear differential, i am probably the just the person you are looking for.. The easiest way to tell if the model 20 still has two piece axles is to look at the hubs near the lug nuts. If you see a nut in the center of the axel(as if to tighten two things together) you still have the two pice axles. Just a bit of advice...... I would swap over to a one pice axel right away if you do any four wheeling with oversize tires. My recomendation is the superior axel kit. That is what i have,..... :2thumup:
#6 User is offline   Rollbar
Posted 02 July 2003 - 09:17 PM
Thanks jeepincj78,
Rollbar
#7 User is offline   jeepincj78
  • Brigadier General
Posted 05 July 2003 - 07:47 PM
Any time I can lend a hand and not get dirty, sounds good to me!!!!!!!!!!!!
Just kidding!!!!!:cry:
