This winch is factory spooled with synthetic rope and comes with a std wired and wireless remotes. Lots of winches out there claim to be waterproof, but this one actually has an IP67 certification to back up the claim. Look at the pricing of a waterproof winch rated with the same line pull then add synthetic rope and a wireless remote and you'll see this is an excellent deal. You can buy this direct from the manufacturer for $699.99 plus shipping PT#264100PPW I am offering this for $550 shipped anywhere in the coolest 48.
In perspective, the Warn 9.5 XP ($1484.99) has the fasted line speed rating at 38ft per min. The RECON is rated at 28ft (pretty fast)per min but can pull 1K LBS more. WARN claims "extreme duty water resistance", RECON is IP67 certified waterproof. The RECON also has a more powerful motor hence the greater line pull rating.
Anyone who knows me knows I'm not out to rip anyone off. If you don't know me, I sure you know someone who'll vouch.
Holla back.
PART # 264100PPW - PRO PERFORMANCE SERIES Winch Specs are as follows:
10,500LB, 12VDC 6.5HP MOTOR, 3-Stage Planetary Gear w/ 218:1 Ratio for Exceptional Line Speed, Aluminum Hawse Fairlead, 88ft of 7/16" Synthetic Rope Rated 16,500LBS, Controlled by both Wireless (30ft Range) & Wired Remotes
Performance: 12VDC
Single line rated pull: 10,500lb (4773kg)
Motor: 6.5hp Series Wound (4.9kw)
Solenoid: IP67 Rated against dust and water
Wired Remote: Wired Remote switch, 12ft (3.7m) lead
Wireless Remote: RF Wireless Remote, 30ft (9.14m) range
Gear train: 3 Stage Performance Planetary Gear Train
Gear Reduction Ratio: 218:1 for incredible line speed
Clutch: Sliding Ring Gear
Braking Action: Automatic In-The-Drum
Drum size: Drum size Diameter 2.5"(63.5mm ) Length 8.8"( 224mm)
Synthetic Rope: 88ft of 7/16" diameter (26.5m of 10.5mm) Rated 7.5 tons or 16,500lb
Fairlead: Aluminum Hawse Fairlead
Mounting Pattern: 4.5” x 10” bolt pattern (114.3mm x 254mm)
Battery Recommended: 650CCA minimum for winching
Battery Leads: 2 gauge 72"(1.83m)
Net Weight: 62lb (28kg)
Gross Weight: 66lbs (30kg)
10,500LB Winch from RECON Waterproof, synth line, wireless. NIB
Posted 13 August 2009 - 09:34 AM
MOAB Tested
2006 KJ Turbo Diesel
1997 4Runner w/stuff
Posted 27 August 2009 - 06:00 PM
This weekend only, either winch model $500 shipped to the lower 48. Offer good now through 8/30.
MOAB Tested
Posted 29 August 2009 - 12:01 AM
PM Received!
MOAB Tested
Posted 31 August 2009 - 03:29 PM
Congratulations to everyone who got in on this, you've made a better deal than you know. When I went to place the orders today, I found that the manufacturer decided to increase the retail price $300 which also significantly increased my price. I am working through this with them now so I don't totally lose my butt on the deal.
Those who ordered will get the price they were promised and your orders will go out tomorrow.
The new price on the winches going forward is $600 shipped which is still a great deal for the offering and $399 cheaper than if you bought factory direct.
MOAB Tested
Posted 31 August 2009 - 08:42 PM
have recon been around long? are they any good.
98TJ, 488gears, S30 w OX fr & S44 w OX r, teraflex high steer, teraflex S/T swaybar, 37in. irocs, edge trail jammer, cobra CB, realtree stealth, warn 9.5ti winch w daystar, KC lights, RE 5.5 long arm, 3in body,
Posted 01 September 2009 - 12:41 AM
The company has been around a while but the winches are a new offering. There was a lot of R&D involved in putting the package together, the company is based in Boca Raton but all the winch inventory is currently in CA. I am sure you'll get some real-world feedback from Safari once he gets it installed.
MOAB Tested
Posted 01 September 2009 - 01:21 AM
thank you. have to ask I know how much it can cost for not having a good winch around I do depend on them.
