JEEPTALK.net: Fire Extinguisher Tip - JEEPTALK.net
#1 User is offline   Rollbar
Posted 07 June 2009 - 08:24 PM
Good tip from a friend.
We recently had a Jeep flop on it's side. Fluid ran out of the trans dipstick and onto the headers, where it caught fire. First guy there took his extinguisher and although it said "FULL", it shot nothing but air (powder was packed from sitting in the Jeep). He threw it aside and grabbed a second, which worked, and put out the fire. When he picked up the first one and pulled the trigger again, it worked.
Since then, I take my extinguishers out about twice a year, turn them upside down, and bang on them with a rubber hammer. Cheap insurance that it works when you need it.
Bob
#2 User is offline   JeepNWilly
  • Brigadier General
Posted 07 June 2009 - 10:06 PM
Back when I had a electronic repair business we got visited by an inspector once or twice a year and they inspect all our fire safety items. They would always hit the fire extinguisher with a rubber malet the same way you described.
Willy
Keep Calm And Wave On
Pics:
#3 User is offline   greentj
Posted 07 June 2009 - 10:57 PM
good info there, thanks!
1997 TJ OlllllllO
4 banger / 4.5" procomp lift / 33" KM's BFG / AR wheels / 4.56 gears / e-fan / snorkel
tb spacer / quite a few lights / stinger bumper / cobra cb /
2011 KK []lllllll[] stock
My wife's daily driver
Think twice before you speak once... Renato
Daddy as of 09/02/10
#4 User is offline   RunninBare
Posted 08 June 2009 - 06:31 AM
As a former extinguisher tech I do a little more than that with mine... when you take it out of the bracket or wherever you keep it, turn it upside down and hit it repeadedly with a rubber mallet like you stated (if you do this often you only need hit it with the palm of your hand). After that turn it back and forth (upside down and rightside up) multiple times slowly to feel the powder fall to the top and to the bottom. This is super fine powder and some people may not feel it move. This motion insures the packed powder will break up inside. If your extinguisher is mounted in an easy to get to place, and isn't strapped in with 32 miles of velcro or electrical tape or whatever, you should be able to do this 3 or 4 times a year (don't forget, the vibrations in a Jeep help the powder settle). I check mine before every wheeling trip while I'm putting my stuff in my Jeep.
I ain't as good as I once was, but I'm as good once as I ever was.
http://www.youtube.c...h?v=TZBTyTWOZCM
1-20-2013...end of an error
#5 User is offline   Wardie
Posted 08 June 2009 - 10:25 AM
Great info!!
Never thought of that.
The few fires I had were put out quickly because I was fortunate enough to have extinguishers that worked.
I'll do this often for now on!
#6 User is offline   AllXJ96
  • Master Sergeant
Posted 09 June 2009 - 12:35 PM
Heck having a fire exstinguisher in the first place is a great idea, just ask my JK
96 Jeep Cherokee with 2.5" mystery lift and 31" bald AT's
07 Jeep Wrangler 2Door, Steel Blue, 4" SuperLift, 37" ProComp MTs, ProComp 8179 with Simulated BeadLocks
RIP
01 Jeep Cherokee 4x4 Red, 62mm b/o TB
|¯¯l,[___],
l---L--OlllllllO¬
()_) ()_)--♂-)_)
[url="http://www.jeep4x4center.com/%5B/url]
#7 User is offline   Wildbill
Posted 09 June 2009 - 01:08 PM
Great tip there Rollbar......... I've seen home and business ones serviced this way but never thought about the mobile one.
Yale H.
Port Charlotte, FL
1992 YJ 4.0 HO
Aussie Lockers Frt & Rear
33 x 12.50 Dunlop Mud Rovers
2004 Liberty Sport 3.7L 4X4
stock for now!!!
#8 User is offline   YellowSub2000
Posted 09 June 2009 - 01:11 PM
This would be a great pre-wheeling check for everyone that has one.
No more Jeep. :(
#9 User is offline   Safari Outfitter
Posted 07 July 2009 - 09:06 AM
Thank you for the information. Such a simple thing could save someone's life.
#10 User is offline   RunninBare
Posted 12 November 2009 - 08:57 PM
bump
#11 User is offline   Rollbar
Posted 12 November 2009 - 09:02 PM
Yep, I did it the other week, looked down @ the F.E. in the camper and said to myself, self, this needs to be turned upside down and BEAT on :2thumup: so I did and feel better. It is a good safety tip. Thanks for bringing it back fro remembrance.
#12 User is offline   92SquareEye
  • Gender:Not Telling
Posted 13 November 2009 - 08:22 AM
i just found the bracket to put my second one on. it's been sitting since i did the last rebuild so i'll beat on it good before mounting it...will hit the other on too for good measure. good tip!!
#13 User is offline   StuckZilla
  • Lieutenant Colonel
Posted 14 November 2009 - 03:35 PM
Just did this with the two I keep mounted on my TJ. As very well described in the above you can actually feel the powder inside move. Great information and excellent advice about doing this quarterly. Crap happens, preparation can limit the impact. Thanks!
SFJC President
99 TJ - Wrangler Sport
#14 User is offline   Wildbill
Posted 15 November 2009 - 10:46 PM
This is some worthwhile info....... so I pinned it. :2thumup:
Yale H.
Port Charlotte, FL
1992 YJ 4.0 HO
stock for now!!!
#15 User is offline   MikeJoel
  • Sergeant Major
Posted 05 July 2011 - 09:50 PM
Great tip! Simple but it sure can help save lives. Thanks for sharing!
#16 User is offline   Rollbar
Posted 05 July 2011 - 09:59 PM
U All are :welcome:
One thing though :whistle:
THIS TIP DOES NOT WORK ON SQUARE HEADLIGHTS :tongue1: :biggrin1: :empathy: :whistle: :amazed: :shock: :lol: :blowup: :sos: :flower2:
#17 User is offline   Rollbar
Posted 29 October 2011 - 02:34 PM
That time of the year again to check them :whistle:
