Hummer Intake/Snorkel
Posted 10 May 2009 - 06:15 PM
tcjc/webmaster
Posted 10 May 2009 - 07:09 PM
Posted 10 May 2009 - 07:27 PM
SFJC Member
Posted 10 May 2009 - 07:50 PM
mike
04TJ & 88MJ
Posted 10 May 2009 - 08:23 PM
JeepDew, on May 10 2009, 08:50 PM, said:
mike
basically you can't go that deep with computer being were it's located at least not that i'm aware of. i'm not going that deep. i can keep a eye on the water level if front end drops off into a hole.what i did was cut 4'' hole into cowl ran 4'' hose from there through bulkhead into engine compartment ran hose next a/c compressor cut 4'' hole into stock air box and made connection there. let it be known that things get very tight under cowl were a/c duct is. measure precisly you don't have much room for error. also i had to use a non a/c belt so belt would rub hose. you could probably use smaller hose and not have this problem
tcjc/webmaster
Posted 10 May 2009 - 09:24 PM
Posted 11 May 2009 - 07:35 AM
Posted 11 May 2009 - 07:44 AM
JeepinIan, on May 11 2009, 08:35 AM, said:
This topic that Ian posted has a lot of good info you should review. There are some heads that you can totally submerge for a few and no water would get in. If you go that deep there will be other things you are going to need to worry about... like electronics. I personally think that this is the best snorkel setup to go with if I was ever to do one.
Posted 11 May 2009 - 10:28 AM
Jim B, on May 11 2009, 08:44 AM, said:
Yeah I read that post. I do not plan on submerging my TJ or even take it in deep water if possible.I am building my CJ for that. I want to do this for 2 reasons, 1 as a precaution and 2 for the cold air. On of thing I do not like about the precleaner is that is it bulky.
Posted 11 May 2009 - 04:34 PM
JeepNWilly, on May 10 2009, 10:24 PM, said:
i bought it off e-bay from a place called tnj murray worldwide there web sight is www.tnjmurray.com so you can buy direct. the part is for a m35 military truck.it's called a air intake cap it cost me $22 for part and $12 to ship. the part came with a 4'' id pipe it also comes drab green what i did was sand it and paint it gloss black with a rattle can it came out real nice kind of low profile. just not low enough to lay hood back against winshield but i can live with it
tcjc/webmaster
Posted 11 May 2009 - 04:55 PM
wrangler up, on May 11 2009, 05:34 PM, said:
I am thinking of cutting it down a bit so it will be lower.
Posted 11 May 2009 - 05:44 PM
i cut 2'' off of it. the cap is 10'' across and 9'' high. i can take another 1'' off before it hits windshield frame on bottom edge of cap.
tcjc/webmaster
Posted 22 May 2009 - 11:36 AM
Posted 24 May 2009 - 10:42 AM
ljrubitm, on May 22 2009, 12:36 PM, said:
You can't open the hood all the way to the windshield, but you can still open it normally--the M35's intake cap is larger than that of a Hummer but much easier to find.
Here's mine:
http://www.flickr.com/photos/lurkzilla/set...57605496783583/
And as far as depth...you can always extend the tube, but really, if you're in over your windshield, you're screwed anyway.
Oh, and Willy, my fuel efficiency actually took a hit after this. Not too bad, but still--besides for me, it's worth the extra piece of mind when Corbett gets deep ; )
