So after going to river rock and blowing a bead i decided it was time to get some bead locks. I did not want to spend to much being that i will moct likly not be able to use these rims forever being that i will be upgrading my axles ad will change my lug pattern. After a couple hours of research i found the billistic simple bead locks for the 15 inch rim. they are only $37 a rim for the inner and outer ring.
first i had to gring the lip of the rim so that the ring would have good surface to weld to then set the ring in and make sure it is centered
next go around the ring and do some tach welds to hold the ring in place and to help from warping the rim.
next weld around the rim.
next step would be painting the rims so that the inners will not rust.
then paint the outers
next mount the inner bead of the tire on the rim.
then take the take the outter ring and center it on the tire. i put a 5 gal drum under the rim to hold the bead and make it easier to center the ring.
after theat take the bolts and evenly put them in
i put all the bolts at 15lbs the spec is between 10 and 20 lbs.
i have about 12 hours into the whole upgrade. i will post up pics of when i get them on the jeep tomarrow i still have to get them balanced.
Rocktime Gets Beadlocks
Posted 20 April 2009 - 08:36 PM
1997 wrangler
38.5/14.5 tsl sx
Ballistic fab beadlocks
cobra 19 cb
superwinch 9500lb winch
8 inch fabtech rock crawler kit
3 inch body lift
and more...
38.5/14.5 tsl sx
cobra 19 cb
3 inch body lift
and more...
Posted 21 April 2009 - 10:11 AM
Can you take a picture of the inner side, I like to see how it looks.
My eyes are hurting, post up 640x480 size pics. These pics are too small.
Posted 28 April 2009 - 05:25 PM
Hey, how do these balance out? I've been wondering about how well weld in beadlocks balance out.
Posted 28 April 2009 - 05:41 PM
they all balanced out fine
1997 wrangler
38.5/14.5 tsl sx
cobra 19 cb
3 inch body lift
and more...
38.5/14.5 tsl sx
cobra 19 cb
3 inch body lift
and more...
Posted 31 August 2009 - 10:23 AM
have you had any sealing issues with these?
74' CJ5
00' TJ
86' BLONDE
00' TJ
86' BLONDE
