Internal or External Beadlocks
Posted 02 April 2009 - 05:31 AM
are there other choices
http://www.cwibeadlock.com/
http://www.high-impa...heels/index.htm
http://www.diy4x.com/beadlocks.htm
http://www.rockstomp...s/beadlocks.htm
http://www.omfperformance.com/
http://www.hutchinso...m/beadlocks.htm
http://www.eco4wd.co...BeadLockHow.htm
Posted 02 April 2009 - 06:24 AM
![:good2:](http://jeeptalk.net/public/style_emoticons/default/2thumbup.gif)
![:2thumup:](http://jeeptalk.net/public/style_emoticons/default/banghead1.gif)
The thing I liked the most about the internal beadlocks is that you are actually locking both sides of the tire and not only the outside, they also work like a run flat in case you punch a tire.
![:lol:](http://jeeptalk.net/public/style_emoticons/default/2cent.gif)
Gus
PS: I know they are not cheap but they work!!!
![:lol:](http://jeeptalk.net/public/style_emoticons/default/2thumbup.gif)
![:nono:](http://jeeptalk.net/public/style_emoticons/default/click.gif)
Posted 02 April 2009 - 12:36 PM
Posted 02 April 2009 - 09:20 PM
![:lol:](http://jeeptalk.net/public/style_emoticons/default/help.gif)
![:rof:](http://jeeptalk.net/public/style_emoticons/default/lol.gif)
![:lol:](http://jeeptalk.net/public/style_emoticons/default/lol.gif)
![:whistle:](http://jeeptalk.net/public/style_emoticons/default/2thumbup.gif)
Posted 02 April 2009 - 09:36 PM
you stated inner and outer. (left side rim or right side rim)
![:lol:](http://jeeptalk.net/public/style_emoticons/default/unsure.gif)
i stated internal or external.(inside tire or outside tire)
![:whistle:](http://jeeptalk.net/public/style_emoticons/default/banghead1.gif)
if i would use external, i think i would use them on both sides of rim.
one internal does both.
![:rof:](http://jeeptalk.net/public/style_emoticons/default/scratch.gif)
i am so confused
![:cry:](http://jeeptalk.net/public/style_emoticons/default/wacko.gif)
Posted 03 April 2009 - 06:02 AM
link 1
link 2
link 3
Posted 03 April 2009 - 07:27 AM
I guess my question with inner beadlocks (the ones that install inside the tire and lock both sides) would be...
what about a tire slice close to the bead area.
I've seen plenty of these on sidewalls that were plugged with as many as 6 and kept going with outer (external) beadlocks.
What if the inner beadlock tube got sliced.
![:2thumup:](http://jeeptalk.net/public/style_emoticons/default/scratch.gif)
![:unsure:](http://jeeptalk.net/public/style_emoticons/default/unsure.gif)
![:unsure:](http://jeeptalk.net/public/style_emoticons/default/scratch.gif)
![Posted Image](http://worldoversea.com/albums/miscweb/willyjim.gif)
![Posted Image](http://www.worldoversea.com/albums/miscweb/onlyinwillys1.png)
Posted 03 April 2009 - 09:35 AM
Posted 04 April 2009 - 03:32 PM
TranyDoctor, on Apr 3 2009, 10:35 AM, said:
One plate per wheel on the outside with aluminum wheel. The rear of the wheel still needs to break the lock and has never come off on me.
I do like the two piece H1 rims but don't know enough people personally that use them to the fullest to determine if they bend after a while. I know for a fact that my aluminums don't bend.
I just recently mounted 4 new tires, you can do this yourself, the hardest part is to break the inner bead, you can do it with a high lift or get a bead breaker kit that is small enough to carry anywhere.
Below are the wheels and plates.
![Posted Image](http://www.worldoversea.com/albums/beadlocks/IMG_0840.jpg)
![Posted Image](http://www.worldoversea.com/albums/beadlocks/IMG_0837a.jpg)
![Posted Image](http://www.worldoversea.com/albums/beadlocks/IMG_0836a.jpg)
Bead Breaker Kit
![Posted Image](http://www.worldoversea.com/albums/beadlocks/IMG_0838a.jpg)
Some plates are now bigger but I personally don't like them because of water, mud and dirt. Most have these to protect the valve stems. I don't use steel post stems so they give and mine are towards the rear.
Here are my new shoes mounted and grooved.
![Posted Image](http://www.worldoversea.com/albums/beadlocks/IMG_0975a.jpg)
Posted 05 April 2009 - 10:22 PM
TranyDoctor, on Apr 2 2009, 10:36 PM, said:
![:scratch:](http://jeeptalk.net/public/style_emoticons/default/unsure.gif)
![:first:](http://jeeptalk.net/public/style_emoticons/default/banghead1.gif)
![:scratch:](http://jeeptalk.net/public/style_emoticons/default/scratch.gif)
i am so confused
![:scratch:](http://jeeptalk.net/public/style_emoticons/default/wacko.gif)
Sorry, When I said inner, I meant inside the tire as TallJeep was explaining.
Posted 05 April 2009 - 10:30 PM
Jim are these Bias TSL's or what? I was going to put the Radial 37" Irocs on my scrambler for ride and all around performance. Sorry didn't mean to hyjack the post. Just curious about a radial heating up when used with bead locks.
Posted 06 April 2009 - 08:59 AM
SodMan, on Apr 5 2009, 11:30 PM, said:
These are Bias TSL SXs. There is no difference on a tire heating up more or less just because one is bead locked and the other is not. Never notice any difference on the road either.
I have two sets of rims, one offroad and one for road. I use Interco SSRs for the on road set. It's nice all around but depending on what you are doing I might actually like and I'm sure others have other models in mind. I personally do not like IROKs, especially the radials. I have witness them and they are horrible, especially when they are cut. Start another topic so you don't get us in trouble.
![:first:](http://jeeptalk.net/public/style_emoticons/default/grin.gif)
