Paint Applications 101 ask your paint questions here
#61
Posted 23 April 2009 - 06:22 PM
I tend to do @ least three coats inner/outer if not more. I was hoping to have some left & pumped into a spray can to carry on the trail
P.S. How long should I wait between coats an hour w/the sun beating on it
#62
Posted 23 April 2009 - 06:36 PM
the plan is .( hardtop first ) ... im starting prep tomarrow night .... 1 cover the jeep with painters sheet plastic prep the tops ...wash it down with T115 all purpose prep-sol cleaner , then spray on 2 coats and allow to dry over night .
day 2 : saturday : do body repairs prep exterior body spot prime as needed .
day 3 : sunday : do final prep and washdown exterior body ..move jeep over to spray booth , finish covering remaining items wet rag entire exterior and tack rag .
and spray it .allow to dry over night
monday morning 3:00am untape the jeep move it out in the morning sun and deliver .
Note : Rollbar heres a tip take a clean wet rag and wipe over your surface parts and see if anything reacts ....if the water doesnt the paint wont .
#63
Posted 23 April 2009 - 06:43 PM
#64
Posted 23 April 2009 - 06:46 PM
#65
Posted 24 April 2009 - 06:21 PM
Go here for more pics (post number 111) --> http://jeeptalk.net/index.php?showtopic=44...mp;#entry116871
Painting tub
Waiting second coat-this stuff drys fast in this heat so I waited about 30min
Applying second heavy coat
Tailgate latches OD
Final paint now drying
Installing rock guards later so they will hide the damaged spots & I fill /soaked them w/POR-15
Roll bar foot sprayed w/U-POL to blend in w/the bed-liner
Underside of hood, note the black accents w/POR-15
Look at that sweet CJ grill, just as happy as can be
P.S. Skinner, thank you for all your help I couldn't have done it w/out you and Daves help
#66
Posted 24 April 2009 - 07:27 PM
now heres the start of my weekend project
heres the stripped T/J in the booth
the prep and cover work
the wipe down
given it a final blow to make sure any remaining dust is gone
preped and ready to shoot
these are the paint products the capt. chose for his hard top
dont forget your resperator kids ....this type of paint will really rattle your brain cells .
FAST .
a final tack of the surface
first coat applied
2nd. coat finish shots
Details .
first i started out the job by washing it down with T115 prep sol cleaner to remove any and all contaminates , then i scuffed the top with 320 grit hand sand
keep in mind that its not wise to dig in to hard because it is a textured finish . then i followed up with a scotch brite pad . then i covered the entire jeep mixed my paint as required .
now with this type of application it is very important to mix properly because just alittle to much catalyst or not enough catalyst will change how the finish looks dramatically . the mixture for this application is 2-1.5-10 % to a cap full of accelerator 9938 .
i then followed up with a wet rag , blow dry, tack rag , applied my 2 coats of top coat , waiting 15 minutes between coats ,
and the capt. has a brandnew ....semi gloss matt finish black hardtop .
thats 1 New tire mounted and balanced in the bag .......Easy money .....total time 3hrs. 15 minutes .i sorta took my time .......2 more tires to go .....
#67
Posted 24 April 2009 - 07:33 PM
#68
Posted 24 April 2009 - 07:36 PM
Rollbar, on Apr 24 2009, 08:33 PM, said:
thats not a paint booth lol.....thats the pre prep area you will see the real booth when i post the final paint pics ,,,,,the booth we have is killer ....water drop flow ...exhaust blowers the works .....
#69
Posted 24 April 2009 - 07:48 PM
P.S. ?-I applied a full Qt. to the hood/fenders etc. & a almost a full Qt to the tub's body, is that enough? I guess it's gonna have to be
?-If I get one of these in the future and I mix the paint w/reducer w/it last like regular rattle cans for touch up use or will it get hard etc. I have almost two Qt's left and would like to use it for touch up's.
Eastwood Spray can
#70
Posted 24 April 2009 - 07:51 PM
#71
Posted 24 April 2009 - 07:58 PM
#72
Posted 24 April 2009 - 08:03 PM
Rollbar, on Apr 24 2009, 08:58 PM, said:
well of course i had 80psi. continual feed to the gun pot...remember im working with huge company air pressure system . my fan was set at 7in span , air to gun at 40psi
air guaged at hand set 15psi 1st coat 22 psi 2nd .
keep in mind with the industrial air feed at work we have endless air feed supply .
#73
Posted 24 April 2009 - 08:17 PM
#74
Posted 25 April 2009 - 04:04 AM
i forgot to add this pic last night
this is the T115 prep sol pre clean this stuff is the best
however its not recommended for use by the general public . thats why you wont find it at auto zone or pep boys , or tractor supply .
gloves and resperator is highly recommended when using this cleaning product , this stuff will kill your brain cells real fast . but its great stuff and really does a super job of contaminate removal .
Warning : for those of you that hinge on just a few cells left ...use of this product isnt recommended .........
heres the tires im hustlin for this weekend all i need is 3 for the Y/J because i already have 1 brand new 1 .
when i deliver the jeep to the capt. and get paid the order is bein made ....unless somebody shows me a better deal on some 33's by next week .
$587.00 for (3) delivered to my door . pretty good deal i think .
well off to work now ....tonight i will be posting some prep & bodywork shots
#75
Posted 25 April 2009 - 04:35 PM
i took a load of pics to many to load here so heres the link check em out ...if you have any questions feel free to ask ..............
http://s253.photobucket.com/albums/hh71/GZ...mview=slideshow
p.s. this is how you deliver a showroom finish to a jeep . the right way .............
#76
Posted 25 April 2009 - 05:16 PM
#77
Posted 25 April 2009 - 06:58 PM
yeah the spray booth is sweet and big ....in a crunch id say you could stuff 6 jeeps in there maybe packed tight ....its a big 1 . having a booth at your disposal sure makes a difference in your job .....
but hey rollbar did a good job given the elements he was dealing with ....in a booth you can control most of the elements , air flow , dust, contaminates etc , outside like rollbar did his you control NOTHING , i'll take a booth anyday .
#78
Posted 25 April 2009 - 09:06 PM
Olive Draaaaaabbbb
Ya, it was nice out, a little wind but sunny. I had the Jeep in full sun and it was to hot to the touch (ouch) so I moved it in the shade while we put the plastic over the top. By then it was cooled down to shade temp. Not sure but if I would have shot the Jeep w/the metal that hot, one, it would have dried fast (per coat), and second, well.............what do you have to say about that?
#79
Posted 26 April 2009 - 04:28 AM
weeeeeellllllll 1. thats exactly what i mean you had to deal with alot of elements to get your job completed , that why i like a booth anytime ,
2. NO Way would i spray topcoat on a hot metal surface , that truly askin for dry spots and uneven finish .
keep in mind most guys that paint a jeep just wanna pound the paint on etc , and just wanna be done with it because 8 out of 10 times its a trail rig anyway and they dont really care how it looks , hence the use of the dreded and evil RATTLECAN approach ,
i on the other hand have to deal with finishes that there better not be a spec in the hood , or a door panel , and apperance and over-all finish means everything
with the effort involved , the time put in , materials , bodywork etc , the job on this 02' T/J i just did cost this capt. almost $1200.00 which $350 of that was materials and his factory paint kit alone .
as far as my work goes over-all apperance and the delivery of a quality finish is everything .
#80
Posted 26 April 2009 - 11:09 AM
here is the link to the gallery of the job from start to finish :
every effort was taken from start to finish to delivery a top quality finish
i can already smell those new tires ...............
#81
Posted 27 April 2009 - 03:49 AM
Alright who's next ???..........................
And alot of you know me and you know if i paint your jeep its gonna look killer ..............and i will give you execellent advice .
#82
Posted 27 April 2009 - 07:13 AM
and now im tire shopping ............
#83
Posted 27 April 2009 - 10:48 PM
Rest can be seen HERE . Page 4, post 113
Question: some say I should paint the grill black?????????????
#84
Posted 28 April 2009 - 06:01 AM
#85
Posted 20 May 2009 - 07:25 PM
my friend just had his jeep painted single stage (looks great) and i want to have mine painted the same color it is now (originally it was white and now it is green). the white is showing through in the most "buffed" places on the hood and have some minor rust to fix, not to mention the person who painted it green didn't take the fender flairs off so you can see the white in the corners. my friend painted his jeep with a (sorry i dont know the correct terms) one stage paint??? not base coat /clear coat.
which is better? base coat/ clear coat or the other, one stage?? i want it to look good and last a while. i do go off road, but when i wax it, i want it to look good.
i am gonna take off all the parts like the brackets, lights, and chrome and buy the paint. the body/paint guy is just going to fix the minor rust, prep, and paint. he wants $1,200 to do that in single stage paint. is that a good deal or should i get another quote? and should i go with base coat/clear coat or single stage??
sorry, i know nothing about paint and body, that's my weak side.
thanks for your input/help.
i let the wife drive it every now and then!!!
Treasure Coast Jeep Club
86 CJ-7, 258 CID, 5 spd, 2 1/2" springs, 1" body lift, webber carb, HEI ignition, 30 front, 44 rear, 3.31 gears, and 33x12.50-15 cooper STT's
#86
Posted 21 May 2009 - 10:23 AM
it sounds like of couse the green is starting to wear thats why you see the white ..
i would reccomend .... base-coat clear coat ...it does cost alittle more but it is more durable then single stage .
the only draw back to the base coat clear coat system is its difficult to touch up .also just make sure who ever does the painting for you knows what they are doing ...
that base coat can be alittle tricky to apply .
yeah $1200.00 seems about right for single stage ...remember like 300 - 400 of that generally is materials alone .
but if your gonna remove everything ...... $1200.00 is alittle costly if your doin all the parts removal yourself .
i myself would charge about $1000.00 for that job but i would need to see it
#87
Posted 21 May 2009 - 03:58 PM
im gonna get a diffrent quote!
thanks again for the advice.
#88
Posted 22 May 2009 - 03:55 AM
yeah i would if i were you ...if your stripin it and buying the paint ahead of time ....$1200.00 is alittle steep now if the body was in real ruff shape or something that 1 thing but i dont see $1200.00 worth of work there ...unless the other side of the jeep is all beat up and im just not seein it .
#89
Posted 14 September 2009 - 05:13 PM
2003 Dodge Ram Quad Cab
Member: Square Headlight Intense Team
Always looking to get dirty…
…daddy to be... 8/27/10
"If you don't stand behind our troops, please feel free to stand in front of them"
"Dont quote me on anything i say from knowledge.. only experience"
#90
Posted 11 July 2010 - 04:48 PM
Faded & dull paint
Rust on passenger side corner panel
Driver's side corner panel
Under hood hinges
Stripped, ready for body work & paint
Finished product
Custom bumper & hitch cover
