Computer Fried/Need New One
#31
Posted 07 March 2009 - 06:10 PM
operating systems
I like having my own operating system disc as I don't have to worry about OEM crap.
I just put together a dual core CPU, 2 gig ram, 250 HD for about $500. I am reusing DVD writer form old computer. I figure to buy it would cost about $1K or more.
#32
Posted 07 March 2009 - 06:18 PM
#33
Posted 07 March 2009 - 06:23 PM
Hows this one.
http://www.tigerdirect.com/applications/Se...mp;sku=B69-2013
I have no idea what all this means. If I install the MB then HD I would then transfer data or install a new OS.
#34
Posted 07 March 2009 - 06:43 PM
You would install an operating system, then take the data from your HD and copy it to the HD that you would need w/ the new MB. You only gto 6 gigs left on our HD now, so getting a new one i swaht needs to be done anyways.
QWhen you install an OS, it gets configured w. the hardware you have in the 'puter you are installing it on. I have used an HD that had an OS on it and swapped it to another MB. It was a real PITA and never worked right.
Just hink, if you get a complete new OS, you never have to but another one.
You probably do'y need a quad core CPU, although it would be nice. I would spend the money on a dual core w/ 2 gigs ram,
#35
Posted 07 March 2009 - 06:54 PM
Also, How do I know if this MB takes the DDR or DDR2, what HD goes w/this board
Peach wants this taken care of cause, ............. well, w/out a PC (L-top don't coun't) she knows I get withdrawls from JT and other Jeep forums.
So, MB, Ram, HD, OS, Transfer old HD Data. Complete. But I wouldn't know where to hook anything up, I guess it comes w/a book.
P.S. Peach just called & wants me to go to B-Buy and others & look, we will C.
#36
Posted 07 March 2009 - 07:00 PM
Would it be better to go w/the VISTA since the XP is no longer supported as much.
What's the difference between Vista home Premium and Business or Ultimate.
Also between 32 bit & 64 bit.
Does MS Office come w/the OS you purchase or does it have to be added?
If U buy a seperate OS & SP1 (service pack) can U down load the new updates like SP2 etc. when MS comes out w/them since U didn't buy a bundled unit from B-Buy etc.?
See Admin, Willy was right
#37
Posted 07 March 2009 - 07:49 PM
I don't know what RAM you MB takes, I would just get new RAM for the new MB.
Personally, I like XP and do not want to go to Vista. I have Vista on a LT.
The I don't know the differences w/ Vista, but w/ Xp you get more things that you can do.
64 bit is suppossed to be better, I have never used it, so I can't comment on it.
When you buy the OS, you can get all the updatees that MS has for it.
The OS does not come w/ Office, that is a separate software bundle.
Oh, the MBs come w/ instructions, in this case READ THEM FIRST!
#38
Posted 07 March 2009 - 08:04 PM
JeepinIan, on Mar 7 2009, 07:49 PM, said:
I agree w/the XP system but one day the XP will be like Win98 and a upgrade will be needed.
U know I only look @ pics.
So, IF I go w/this I just but the guts & put them in the HP case I have now, correct?
OK, I'll lay everything out and see if I missed anything. Then I'll compare to a crackerjack bundle.
Stay tuned
#39
Posted 07 March 2009 - 08:33 PM
1. http://www.tigerdirect.com/applications/Se...mp;sku=B69-2013 - MB - This comes w/the Processor (CPU) right? $189.99
2. http://www.tigerdirect.com/applications/Se...p;sku=TSD-750AS - HD $89.99
3. http://www.tigerdirect.com/applications/Se...mp;sku=K24-5844 + I have a brand new 1gig DDR2. I can use regular RAM or do I need a dual channel, or is Dual channel just two sticks. $12.99ea.
4. Can I use my old power supply? - http://www.tigerdirect.com/applications/Ca...=Power-Supplies $30.00 +/-
5. Fan, but which one for this MB - http://www.tigerdirect.com/applications/ca...&srkey=fans // http://www.tigerdirect.com/applications/ca...essor-Fans& // Do I need a HD fan? $25.00 +/-
6. DVD/CD - http://www.tigerdirect.com/applications/Ca...=CD-DVD-Burners // http://www.tigerdirect.com/applications/Se...p;sku=S167-4520 $39.99
7. Modem - http://www.tigerdirect.com/applications/Se...mp;sku=U13-4062 // Do I need this or does the MB have the Ethernet hook up. $29.99
8. Sound Card - don't even know but 30 bucks sounds good to me // http://www.tigerdirect.com/applications/Ca...me=Sounds-Cards $35.00
9. OS - http://www.tigerdirect.com/applications/Se...5&CatId=306 $189.00
Total-$654.94 w/two ram sticks. Wow
#40
Posted 07 March 2009 - 10:18 PM
That all looks good, you just need DDR2 RAM. A second stick might or might not work. MB bundle does come w/ a CPU.
Your power supply wioll not connect to the SATA drives.
You need one for an AMD 2+, which is what the MB you have listed supports.
As long as it's SATA drive, you're OK.
Both of these are on the MB.
Looks good.
OR
You could go THIS WAY and add THIS FAN using THIS GEL )so the heat sink does it's job the best it can, for a lot less money.
Be sure to still get the DVD drive.
#41
Posted 07 March 2009 - 10:30 PM
http://www.officedepot.com/catalog/search....7&Ne=307622
Wow- so I get this-
http://www.tigerdirect.com/applications/Se...u=M452-2671%20A $219.00 + 19.98 + 15.00 + 30.00 + 189.00OS =$472.95
Comes w/moden etc built in and BIOS. Basically, put it together w/the DVD and Install the OS and transfer teh old HD info and go.
I would get two of these OR does the package come w/this SIZE Ram. I see two but would rather get the bigger ones. Speed man, speed.
Cool, thank you very much for your help Ian/willy, I'll let you know.
#42
Posted 07 March 2009 - 10:52 PM
http://www.nextag.com/HP-Pavilion-Slimline...9061D3FC903193E
http://www.nextag.com/HP-Pavilion-Slimline...0381/specs-html
I see they list comparison prices but not sure where to pick one of these up at if I were to do so.
#43
Posted 08 March 2009 - 06:46 PM
It's all about how much work you want to put into a 'puter. time = money.
#44
Posted 08 March 2009 - 08:13 PM
Thanks for the help all, I'll keep U posted.
#45
Posted 08 March 2009 - 09:17 PM
#46
Posted 08 March 2009 - 09:34 PM
32 bit or 64 bit. Basically is a larger memory address space the problem is that most software out there are still being developed based on 32bit. Some will work on a 64bit PC but others amy not. I would say stay with 32 bit since not all apps will work on 64 bit like your AutoCad unless you get AutoCad 2009.
I have used http://www.pricewatch.com at tim when building PC's
#47
Posted 08 March 2009 - 09:53 PM
Major question to follow, remember a few weeks ago I was talking about speed on my two PC's. Well the one that had a clog or choke down in it some where and no one (others) could figure it out. At the modem it was full bore but at the PC it was at half speed.
Here's the question, would the choke down be in the HD or on the MB. I know U can't give a definite but usually they are in the MB right if everything is working good off the HD.
Signed,
Getting better at VISTA
#48
Posted 08 March 2009 - 11:00 PM
#49
Posted 09 March 2009 - 07:48 AM
Signed,
The HD is just for storage. All prgrams load up to memory and run from there. They will use the RAM memory as well as the HD swap space. I have never seen a HD get slower because it is going bad. Most of the time you will start see bad sectors showing up. I have also notice a HD become read only a few days before crashing.
As far as the choke down it is more like software on you PC like spyware. They are known for choking up a PC. Also if your CPU fan is not working or if your heat fins under the fan are clogged with dust and the CPU cannot get as cool as it needs to be they will throttle down to prevent overheating.
#50
Posted 09 March 2009 - 09:10 AM
I appears you don't even need a high-end one since most of your computing is internet stuff and Microsoft Office stuff. You seem like a perfect candidate for the Mac-mini. (Yes, they run Windows OS and Mac OS) Ask around, look into it...just a thought.
#51
Posted 09 March 2009 - 09:34 AM
Nope, never thought of it. Most of my programs are windows though. Any suggestions, plans, software etc? I did use a MAC at a wedding one time and to me it ws hard to navigate but i wasn't use to it. Felt like I had to call everything up manually...not sure but that was my perception. Still open..............
Willy I do have Super AntiSpyware, Super AdBlocker (same company, lifetime service) & Malware installed on all PC/L-Top.
#52
Posted 09 March 2009 - 10:25 AM
X2
#53
Posted 09 March 2009 - 10:27 AM
#54
Posted 09 March 2009 - 10:33 AM
JeepNWilly, on Mar 9 2009, 11:27 AM, said:
Did you place your vote on the poll I posted in Chit-Chat
At lease I'm not afraid to ask the questions that so many want to ask that's how we learn & I think you have a excellent idea we need a place to discuss PC issues , that's what family is for Maybe a more specific poll is needed or U can PM Admin
#55
Posted 12 March 2009 - 03:44 PM
I have office 2003 and other duplicates on the Vista now. I don't want it to duplicate everything. Will it ask for clearification? Will it transfer all my outlook e-mails etc.
Just want to know B-4 I get it cause I won't be fixing my PC for a little while yet.
P.S. Please vote - http://jeeptalk.net/index.php?showtopic=15...mp;#entry113605 I ought to add this to my sig line but Admin would probably omit it
#56
Posted 12 March 2009 - 08:59 PM
It just gives you the means of getting into your HD from another PC to get all your user data off (pics, documents,etc....) without having to pay some computer shot to do it for you.
PS: I voted
#57
Posted 12 March 2009 - 09:11 PM
P.S> I ordered one today at the request of Peach so she wouldn't hear me cry anymore.
#58
Posted 12 March 2009 - 09:14 PM
#59
Posted 12 March 2009 - 09:19 PM
One thing I don't understand is after the warning it took time for things to move but they did, like the memory was frozen up. I was able to move the mouse & everything soi though I would restart it, then t wouldn't re-boot. It might be something simple.
#60
Posted 12 March 2009 - 09:27 PM
