304-360 Cubic Inch Displacement
Description
Torque
(ft. lbs. unless noted)
Alternator-to-Mounting Bracket Nuts
30-35
Alternator Bracket to Lower Support Nuts
18-25
Alternator Support Bracket to Cylinder Head Bolts
25-30
Alternator Adjusting Strap to Alternator Bolts
18-25
Camshaft Front Lock Bolt
25-35
Carburetor Adapter to Manifold Screws - 2V
18-25
Carburetor Hold-Down Nuts
12-15
Coil Mounting Bracket Bolts
30-35
Connecting Rod Nuts
26-30
Cylinder Head Bolts
105-115
Crankshaft Pulley Attachment Bolts
18-25
Clutch Housing Spacer to Block Screws
10-13
Clutch or Converter Housing to Block
25-28
Distributor Clamp Screws
10-15
Drive Plate to Converter
21-23
Fan Spacer to Water Pump Bolts
18-25
Flywheel or Drive Plate to Crankshaft Bolts
100-110
Front Engine Cover to Block Bolts
20-30
Fuel Pump Screws
30-35
Main Bearing Cap Screws
95-105
Manifold:
Air Injection Tube to Manifold
35-40
Air Pump Bracket to Cylinder Head
40-45
Air Pump to Mounting Bracket Nut
20-25
Air Pump Pulley Bolt
5-8
Air Pump Reinforcement Nut
18-25
Air Pump Reinforcement Bolt to Water Pump Nut
25-35
By-Pass Valve Bracket to Stud Nut
18-25
Choke Heater Tube Bolt
10-12
Diverter Bracket to Valve Bolt
5-8
Exhaust Manifold to Cylinder Head Bolt
30-35
Exhaust Pipe to Manifold Nut
20-25
Intake Manifold to Cylinder Head Bolt
40-45
Mounting and Connecting Parts:
Engine Mounting Bracket to Engine Bolt
25-30
Engine Mounting Bracket to Frame Bolt
30-35
Cushion to Support and to Frame Bracket Nut
30-35
Insulator Assembly to Cross member Locknut
25-30
Mounting to Adapter Bolt
25-30
Adapter to Transmission Bolt
15-20
Insulator and Bracket to Transmission Bolt
25-30
Insulator to Cross member Locknut
25-30
Insulator to Transfer Case Locknut
15-20
Insulator to Transfer Case Screw
20-30
Torque Reaction Bracket to Transfer Case Bolt
25-30
Oil Pump Cover Bolts
48-60 in. lbs.
Oil Pan Screws ¼"-20
5-8
Oil Pan Screws 5/16"-18
10-12
Rocker Arm Screws
20-30 in. lbs.
Rocker Arm Cover Screws
20-30 in. lbs.
Rocker Arm Retainer Studs
65-70
Rocker Arm Retainer Stud Nuts
20-25
Spark Plugs
25-30
Starter to Engine Bolts
30-35
Thermostat Housing Bolts
18-25
Vibration Damper Retainer Bolt
50-60
Water Pump to Block Bolts
40-45
Water Pump to Front Cover Bolts
45-50 in. lbs.
Source: 1971 Jeep Service Manual
Posted 31 January 2009 - 03:34 PM
Posted 31 January 2009 - 10:26 PM
401 built right! Crank shaft to transmission 425ft. lbs.
