Vehicle for install, Peaches Jeep. (now that everything is fix on it she wants it back , and painted )
First, get all your tools together.
Second, mark a pilot hole while someone holds step in place and then drill out your pilot hole.
Third, tighten down step so you can mark the other holes for pilot drilling.
Fourth, mark the other holes to be drilled.
Fifth, paint step (after sanding) w/galvanized primer.
Sixth, paint step to desired color.
Seventh, install step.
Note: before you install anything on your spouses Jeep, make sure she understands your text message that you are already in the process.
CJ Stock Step Installation
Posted 06 January 2009 - 07:10 PM
