CV DriveShaft Rebuild
Posted 09 December 2008 - 11:50 AM
New Part, Old Part
Posted 09 December 2008 - 06:59 PM
Posted 09 December 2008 - 07:53 PM
xraydivr, on Dec 9 2008, 04:55 PM, said:
Good point but to be more technical it is actually a "Double Cardon Joint CV Driveshaft"
Mostly referred to for short in the industry as a "CV"
Most have problems with long name and pronunciations such as a "Cardon".
sbmonkey, on Dec 9 2008, 06:59 PM, said:
You might want to call Tom Wood's Custom Drive Shaft, you just might be able to convert a few things.
Posted 10 December 2008 - 09:41 AM
Posted 10 December 2008 - 09:59 PM
YellowSub2000, on Dec 10 2008, 09:41 AM, said:
You rebuilt the centering ball yoke? I am about to do this same rebuild but thought I would just replace it. Is there even a rebuild kit for that?
Posted 11 December 2008 - 08:53 AM
The rubber is there to retain some of the grease and smoother ball travel. One needs to maintain the vehicle by proper greasing at intervals or when submerged in water, mud, etc. EACH TIME... don't let it go for more than a day.
sbmonkey, on Dec 10 2008, 09:59 PM, said:
Replace it if you see any sign of damage period.
Note:
These are not my pictures and not my drive shaft. A good friend sent them to me and I posted these so that people can get an idea on how it is done. I have been maintaining my CV for 10+ years and only had to take it apart once to see that all was in top shape which it was. I regularly grease all my ujoints (I do not over grease which is not good for the seals) and have been problem free unless I break one on the trail which is usually at the Diff end.
Posted 12 December 2008 - 07:15 PM
I inspected all the parts, spring, needle bearings and such. There wasn't any damage that I could see. So I removed the needle bearings(Careful they are small), brake cleaned the heck out of it, put new Lucas grease in it, and carefully put each bearing back in place.
