Uni-Raise
Posted 18 November 2008 - 08:05 AM
Below are some pictures:
Sema 2008 Display
Supporting a TJ AR15
Here you can see the removal saddle
Transmission Supported
Full View with Skid Plate removed
Uni-Raise Brochure
Posted 18 November 2008 - 08:07 AM
Posted 18 November 2008 - 08:09 AM
Posted 18 November 2008 - 08:21 AM
Posted 18 November 2008 - 12:08 PM
Jim B, on Nov 18 2008, 08:21 AM, said:
meegan....do NOT buy that for gustavo. spend the money on something better! when you need it...just go borrow jim b's.
thanks in advance, jim!
ps - very cool gadget.
Posted 19 November 2008 - 01:46 PM
MrsTallJeep, on Nov 18 2008, 12:47 PM, said:
At least you have a garage! We kinda have a temp one but I'm kicking Sandford & Son out any day now!!
Yellow 92 YJ, Elvis, I share with LrdJeffson
Jeep...the power of American manufacturing...600,000 Jeeps deployed during WWII...a vehichle that can go anywhere, do anything...it embodies the American spirit!
Stuck happens! :0
"Your winch or mine?"
"One isn't necessarily born with courage, but one is born with potential. Without courage, we cannot practice any other virtue with consistency. We can't be kind, true, merciful, generous, or honest. You can practice any virtue erratically, but nothing consistently without courage."
"The main thing is to keep the main thing as the main thing." ;)
Member of South Florida Jeep Club
Posted 20 November 2008 - 08:54 AM
Nice setup, would be nice to have this under my TJ.
A good friend that is having this done to his TJ sent me these pics of the Uni-Raise.
At this point I'm more interested in the setup.
Posted 20 November 2008 - 09:15 PM
Posted 23 November 2008 - 11:50 AM
wait, this is only for when you need to do work under there right? This guy sounds like he thinks it is a permanent install? What's the dealio?
Posted 23 November 2008 - 12:53 PM
Port Charlotte, FL
1992 YJ 4.0 HO
Aussie Lockers Frt & Rear
33 x 12.50 Dunlop Mud Rovers
2004 Liberty Sport 3.7L 4X4
stock for now!!!
Posted 23 November 2008 - 10:57 PM
I'll go check this one out for sure....
Posted 24 November 2008 - 07:57 AM
coonbuster, on Nov 23 2008, 11:50 AM, said:
Correct, I think you are mis reading the post. I was admiring the setup that he has with the NV4500 and the 2 speed Atlas.
Wildbill, on Nov 23 2008, 12:53 PM, said:
I do see what you mean but I don't think it's maxed out to the point that is going to snap. They are probably trying to raise the entire drive train to either install or make something fit... who knows.
Some of you fellows really need to read the url link on the first post that has the brochure and has a short brief explanation. This is not an add-on to anything on your vehicle. It is a tool that lets you work on your vehicle and make things a bit simpler to work with.
Posted 25 November 2008 - 09:10 AM
Even though I did not see a problem as I said in my last post I was still wondering about this. Than the closer I looked I noticed that the bow was at the very bottom & sides of the picture itself. Most cameras have what it is called a fisheye effect, if you look closely at the sides of the pic you will also see the minor distortion. I do see just a few mm that you would have to measure with a caliper but I don't think this is even an issue how this uni-raise holds the weight of the entire drive train
That said I wrote to the person that was using it and he advised that there was no bow when lifting the NV4500 with the Atlas 4 speed. He took some pics and sent them to me in a more direct angle with a straight edge.
Posted 25 November 2008 - 09:41 AM
Jim B, on Nov 25 2008, 09:10 AM, said:
man and then they tell me I'm anal....
the tool in questions looks like a great add on but how many times do you really need to get under there, I think Dino should buy one and then rent it out for all those under the tree mechanics.... and seeing that I came up with this marvelous idea, i get to use it first for free....
04TJ & 88MJ
Posted 25 November 2008 - 10:25 AM
JeepDew, on Nov 25 2008, 09:41 AM, said:
I can understand you point when it comes to your mechanics and things that you have experienced on the trail.
Save your money.
Posted 25 November 2008 - 11:06 AM
Jim B, on Nov 25 2008, 10:25 AM, said:
Save your money.
Now that was a low blow.... Jim B....
04TJ & 88MJ
Posted 26 November 2008 - 11:03 AM
Thanks for the additional information....... for the record I wasn't trying to find faults with the product and didn't think that it was going to fail, I was meerly pointing out something I saw. It appears to be a fine product and would consider using/buying one myself.
Port Charlotte, FL
1992 YJ 4.0 HO
stock for now!!!
Posted 26 November 2008 - 11:08 AM
Posted 26 November 2008 - 11:18 AM
Jim B, on Nov 26 2008, 11:08 AM, said:
Yes..... good point
Port Charlotte, FL
1992 YJ 4.0 HO
stock for now!!!
