Do you have the factory tach?
If not there is a very convient plug just off the ignition swich you can use for this 'Kill" switch. May work on the older yJ's, might look to see if you have this set up.
This could go either way for the tech dept or tips/tricks dept?
CJ Ignition Kill Switch
Posted 09 November 2008 - 10:07 PM
Posted 10 November 2008 - 07:21 AM
Good info. I'm sure even if you do have a tach, can't you put in a bypass in the middle and still use the kill switch.
Posted 10 November 2008 - 04:29 PM
Yep, I think so, should be no problem. It's just easier to do it @ the plug & make ends for the switch etc.
Posted 23 November 2008 - 11:09 PM
Nice info...
I have not so good about wirings....
Thanks for sharing this...
