Goblin JK Buildup
Posted 26 October 2008 - 07:04 PM
My JK took a small step forward this weekend towards the realm of modified jeeps thanks to JeepNWilly and Sergio
With their hard work my jeep is now sporting a Rough Country 2.5" BB, Rough Country sway bar quick disconnects and ShrockWorks Rock Sliders.
pics below:
it begins
break time
rails
quick lift comparison
and finally...quick test run at corbett
pics below:
it begins
break time
rails
WICKEDTRAILS4X4.COM
'04 LJ-Wicked Built
'04 LJ-Wicked Built
Posted 26 October 2008 - 09:06 PM
Rollbar, on Oct 26 2008, 08:09 PM, said:
Nice. Now for a front bumper to get rid of those tow hook that could bust & kill some one, they flex real easy.
Who was that masked man
C'mon you can't recognize me in that picture. I had to do a little modification to the Rock Sliders. It called for self tapping bolts in the rear mount point because there was no access for a nut. That was the case for the passenger side but after making the 21/32 holes on the passenger side with the supplied drill bit it wore out. Luckly for the drivers side since the bit was no good anymore there was some access holes where I could place a nut. So I brought out my welder and welded a strip of metal and a washer to the nut and on it went.
PS.. As always Sergio was a big help
Posted 26 October 2008 - 09:22 PM
JeepNWilly, on Oct 26 2008, 10:16 PM, said:
When I get good I will start building my tubefenders and bumpers and you will see that writeup.
Ok, keep us posted.
Would U recomend just welding the nut anyway?
Posted 26 October 2008 - 09:30 PM
Here are the links to the vids taken on the test run.
Me
http://www.flickr.co..._jk/2974697483/
http://www.flickr.co..._jk/2975638858/
Goblin JK
http://www.flickr.co..._jk/2975530114/
Sergio with his new toy 2WD becasue we had to remove the front driveshaft due top the steep driveline angle was causing issues.
http://www.flickr.co..._jk/2975692112/
My TJ looks funny without a bumper
Me
Goblin JK
Posted 27 October 2008 - 03:10 AM
looks pretty good ....did you let sergio fly it yet ?
Question : Was that the shifter you were weldin on ?? if so doin a 2.5 BB on that what was the need for the welding ? i never had to do any of that not even on the 2"BL. are the shifters on the JK that short to be affected that much ?
Posted 27 October 2008 - 08:08 AM
No welding needed at all for the BB. It was the simplest lift I have ever done. I just had to do a little welding to get the driver's side Shrockworks Rock Sliders installed.
See this pic I found in their install guide.
I had to creat another nut just like the one in the pic to do the same exact thing because the drill bit for the self tapping bolts wore out while installing one side.
