XJ Underhood Temp Control
Posted 10 August 2008 - 05:42 PM
Measure a dozen times, cut once.
Honest, these were $5 each.
A little work with the jigsaw and some sanding.
Kind of committed to the project now.
I sprayed the holes with bedliner too to help with rust.
Not too bad.
My son was impressed.
Posted 10 August 2008 - 07:21 PM
Posted 10 August 2008 - 09:23 PM
Rollbar, on Aug 10 2008, 07:21 PM, said:
I have no idea the CFM, but they move a lot of air. About like your typical 6" desk fan. I put them where I had clearance. Not exactly scientific, but there's not much room under there. One is right over the exhaust manifold and the other is right over the intake. No idea how waterproof they are and I used a 10A fuse.
Posted 10 August 2008 - 09:38 PM
Seriously, I love this, you made use of what you had, and i know some fans of that style, they move plenty of air to evacuate a good amount of heat at stop lights and such. And those wooden dieshes are pretty tough. On the highway they may not keep up with the naturaly flow now that you have those holes but that is perfect.. The water proof aspect, I wonder how they will last considering the moisture free environment they where intended for.. However they are well made to begin with.. Keep us updated..
Again, awesome cheap trick..
Posted 10 August 2008 - 09:59 PM
04TJ & 88MJ
Posted 11 August 2008 - 07:21 AM
soflmuddin, on Aug 10 2008, 09:59 PM, said:
Posted 11 August 2008 - 11:46 AM
Posted 11 August 2008 - 02:22 PM
JeepinIan, on Aug 11 2008, 11:46 AM, said:
Probably at highway speeds, but this if for off road where I rarely get over 10-15 MPH. One note of concern here however. I originally wanted to mount the fans to the firewall with ducts running out to the fenders. Would have looked cool, but the unibody would have been weakened (IMO) from a 4" hole in the side. Then I thought about just having them blow directly into the cowl area since it's open anyway. But I happened to think that isn't that where fresh air comes into the cabin? I am hoping that I don't get any CO inside from how I have it now. If I don't post after the next time I take it out, you'll know.
Posted 11 August 2008 - 02:27 PM
Posted 11 August 2008 - 03:11 PM
Posted 11 August 2008 - 06:52 PM
Posted 11 August 2008 - 07:25 PM
I would really perfer to see you clean and sand them then apply a few coats of a nice deep cherry finish.. Come on, you would be one of a kind then..
Posted 11 August 2008 - 07:37 PM
Posted 11 August 2008 - 07:47 PM
Posted 14 August 2008 - 09:22 PM
My only concern is how long will the wood lasts through changing weather conditions....
Posted 17 August 2008 - 07:42 PM
Posted 17 August 2008 - 08:04 PM
Posted 17 August 2008 - 09:20 PM
Posted 18 August 2008 - 08:39 PM
http://go.jeep-xj.in...rRestrictor.htm
I wish I could think of somehting funny to put here...
98' Red TJ, 4.0 I6, 4.5" Lift, Stock Running Gear, 35" Super Swamper Radials, 9500lb MM Winch mounted on Hansen Bumper.
Wish list: Too long to mention...
Member of Caloosa Jeepers of SW FL
http://www.caloosajeepers.com/
Posted 18 August 2008 - 09:00 PM
04TJ & 88MJ
Posted 18 August 2008 - 09:09 PM
That;s a diferent issue. The coolant is going too fast through the block, not allowing the water to actually pick up the heat from it.
http://www.techhoods...ds/Scoop-F1.htm
04TJ & 88MJ
Posted 18 August 2008 - 10:04 PM
#25
Posted 18 August 2008 - 10:16 PM
#26
Posted 19 August 2008 - 07:13 AM
#27
Posted 19 August 2008 - 07:15 AM
#28
Posted 19 August 2008 - 07:45 AM
04TJ & 88MJ
#29
Posted 19 August 2008 - 11:22 AM
