Eaton Detroit Locker
Posted 31 July 2008 - 10:12 AM
it will probably work but it is a huge responsibility for a few $ of profit.
i will inform the customer to grind the clips and install the axles.
Posted 31 July 2008 - 10:18 AM
It is the same thing with the lock right, you have to grind the carrier in order to be able to fit the locker inside and they don't tell you that until you have the part and read the instructions. Can you return the locker ?
Posted 31 July 2008 - 10:22 AM
I was very curious what the specific fit problem was. So Doc you are saying that when the axls are scooted into the diff where you would normally drop or push the Cclips onto the end inside, the axles don't go far enough to show the gap for the Clips, or the Cclips are just too wide? Do the provided Clips fit into the slots when the axles are outside the diff.
The funny thing is that the new 8.25" used in the Grand came into use at around the same time the Liberty started using the 8.25 instead of the D35, mid 06 production for the 07 model year., in the Grands.
Posted 31 July 2008 - 10:36 AM
Posted 31 July 2008 - 10:39 AM
Posted 31 July 2008 - 10:45 AM
I personally would not grind any clips to make something fit especially inside a diff, even if it works, especially on a C clip axle.
If it was my rig I would return the locker and seek another avenue. Some people are different and they would take the chance so I will also say that if I was the installer and the shop, I would make them sign something that when all is working they are basically on their own once they get far enough away from my line of sight. Kind of like what Eaton is telling you. Then you can make your few $ in profit and not have the headache or responsibility.
Posted 31 July 2008 - 10:53 AM
Posted 31 July 2008 - 11:10 AM
The reason I mentioned the new design for the WK is that the housing is totally different from any other 8.25 and the specific problem mentioned here sounds like there may be a link between them. The new housing is a little wider in some dimension than any previous one, not sure exactly where, no one to my knowledge has put a locker other than the factory one in a WK, actually there isn't one made yet. But I also have never heard of anyone putting a Locker in the KJ with a new style 8.25, so in my opinion they are still ordering the locker for any garden variety 8.25 and saying it will work without having any understanding of the part..
The only way to confirm this that I know of is to find out the differences from the old design to the new one, or whether the KJ got the newer designed housing?
Posted 31 July 2008 - 12:01 PM
Anyway, it was great of Dino to spend so much time on this since in reality, he has a business to run and these were not his parts. Everything else he did came out great: 4.10 gears and a DTT up front. I really don't want things chopped up to make them fit so I guess I will fight with 4 WP to get my $600 back.
Thanks Dino for everything...really.
I will call you soon.
2006 KJ Turbo Diesel
1997 4Runner w/stuff
Posted 01 August 2008 - 01:15 PM
