Speed Bleeders Self bleeding brake system
Posted 23 May 2008 - 07:45 AM
Ive been looking at these for a while, but havent had the need for them as of yet. Well after my caliper froze up on me a few weeks ago I decided it was time to order them.
What they are are the bleeder valves in the calipers that allow you to bleed the brake system. They have a check valve built in so you dont need the second person to sit there and either hold the brake or close the valve.
The model number that works for my jeeps is SB3824. But what ive read is that the SB3824HD actually fits better which is made for the harley davidson. And I ordered the SB3824HD-SS which are the stainless steel ones. The standard bleeders are $7 a peice or the stainless steel are $15 a peice.
I think it was a great buy and sure made bleeding my brakes easy, especially after I put all new brake lines in and tightened everything up.
You can purchase them on their website http://www.speedbleeder.com/ or Ive also read somewhere that you can find them in Auto Zone where their HELP section is at, but ive never looked.
Tim
'98 Grand Cherokee
Ru•bi•con n.
'98 Grand Cherokee
Ru•bi•con n.
Posted 23 May 2008 - 07:59 AM
It's a lot better when the brake lines are tight for the car and for the driveway were you are doing the brake job (It's all good my super-duper grease cleaner took care of it )
I'll be going to autozone to see if I can find them, it will make changing my brake lines a lot easier.
Posted 23 May 2008 - 11:07 AM
how long did shipping take?
74' CJ5
00' TJ
86' BLONDE
00' TJ
86' BLONDE
Posted 23 May 2008 - 11:53 AM
I ordered on monday and they were there by thursday priority mail.
Tim
'98 Grand Cherokee
Ru•bi•con n.
'98 Grand Cherokee
Ru•bi•con n.
Posted 23 May 2008 - 10:48 PM
I have these on El Niño. They work great, I purchase a catch cup. Every now and then I still like to have someone on the pedal even though I use them.
Check the Whitney catalog for pricing also.
Posted 25 May 2008 - 01:15 PM
Posted 02 June 2008 - 06:12 PM
Advanced Auto has them in the help section on a blister pack, $9.99 a pack of two, 3/8"x24.. I think the part number was 17071, they don't look to be the exact same quality as the speed bleeders, but they work well enough..
2000 5.2 WJ
