M416 Custom Trailer Not a MIL SPEC Rebuild
Posted 27 April 2008 - 09:28 PM
Here is what it looked like after I got it home.
First order of business was to tear it down.
Next we ordered some humvee lights, seals bearings and I am waiting to hear back on the brake handle. I will be going with a standard trailer jack that is removable.
While waiting on parts we sandblased the frame and cut the crap off the front a-frame and replaced it with a wide plate that will accomodate a custom dry box.
After cleaning-up the brakes and replacing needed parts including bearings and seals. we spot primed and painted some. We Phos treated everything to try and get to any rust that the sand missed. Now it was time for the DP90 epoxy primer. So we picked the windiest day in April to do this
We applied three coats let it sit a day, sanded and put one more coat. We also sandblasted the wheels and painted them metalic silver base coat/clear coat.
I'll get pictures of the wheels up later. Right now I am waiting on a spot at the monument makers sandblaster to blast the tub. It would take entirely to long with our little blaster. We color shot my CJ7 for the base coat/clear coat match. We completed the fenders and the color is very close to my Jeep. I'll post more as we move along. There are more pictures in my albums under m416 if anyone is interested.
Posted 27 April 2008 - 09:31 PM
Posted 28 April 2008 - 08:12 AM
SFJC and 50/50 Offroad Team
Posted 28 April 2008 - 09:05 PM
Wheels
The new lights. Trying to decide on black or color match w/the tub?
The tub is in progress. We sealed the drains with epoxy filler and sheet aluminum. I will be installing small pipes to accomidate boat plugs just in case it gets water in it.
Added some new monroe shocks that were book replacements for a CJ5. They have a longer stroke than the stock units, but my wife said it would be okay
The new jack which will be installed after replacing the tub. I also want to paint it black.
Here are the fenders after painting. They have to wait a while before a wet sand and buffing. The weather wasn't the best for painting, so we have a little orange peel
That's about it for now. If anyone has any artistic or creative ideas I'd like to hear them.
Posted 28 April 2008 - 09:11 PM
P.S. If your Jeep can't pull it then I think my CJ will :sneak:
Posted 28 April 2008 - 09:17 PM
Rollbar, on Apr 28 2008, 10:11 PM, said:
Agreed! I was hoping to go red cause I'm out of dp90. I'm going to have a fortune in paint
Posted 28 April 2008 - 09:51 PM
On the P.S.
Posted 05 May 2008 - 04:52 PM
Posted 05 May 2008 - 04:58 PM
Here's the right front corner without the fuel can. I used polished SS allen head cap screws/bolts. I will be adding some diamond plate in the near future as well.
Here's a picture with the fuel can, but no strap.
Posted 05 May 2008 - 05:11 PM
I can't wait to get back in town to work on it some more. Hopefully I can get the Linex done this week. I'm ready to try it out behind the CJ7
Posted 05 May 2008 - 05:48 PM
Now I have to paint my Jeep the same color if I wany to use it
Very, very, nice.
Posted 05 May 2008 - 05:50 PM
Posted 05 May 2008 - 07:30 PM
i like the color
00' TJ
86' BLONDE
Posted 05 May 2008 - 07:42 PM
Posted 05 May 2008 - 08:04 PM
By the way, does anyone know if there is a pop rivet that is flat on both sides of the attachment? I want the inside of the tub to be as smooth as possible. The only rivets I have; will leave a pin on the inside of the tub.
Posted 05 May 2008 - 08:10 PM
Fasteners.
Posted 05 May 2008 - 08:15 PM
Rollbar, on May 5 2008, 09:10 PM, said:
I thought I had seen them before. It seems like I've seen them on the bottom of air boats. Like when they put the kevlar on the bottom. maybe in aircraft too. I'll check the net.
Thanks, J. Brown
Posted 05 May 2008 - 10:33 PM
Where did you get the lights from? I may consider putting those on mine.
Posted 06 May 2008 - 07:13 AM
Russells JEEP PARTS in Bainbridge GA. I can get you the #. I have a new brake handle waiting on me. I just need to send a money order to have them send it to me. I haven't completed the wiring yet. I want the bottom light on the tail lights wired in with a set of rock lights on a rocker switch inside the Jeep. I just need some time to work on it.
Posted 06 May 2008 - 08:08 AM
Looks great!
Posted 06 May 2008 - 08:38 AM
Wildbill
Port Charlotte, FL
1992 YJ 4.0 HO
Aussie Lockers Frt & Rear
33 x 12.50 Dunlop Mud Rovers
2004 Liberty Sport 3.7L 4X4
stock for now!!!
Posted 06 May 2008 - 09:37 AM
Posted 06 May 2008 - 07:51 PM
The number for JEEP PARTS is 229 377 1528
The guys name is Russell. He has some cool stuff on his lot. I would like to have the Humvee he has sitting there. Only problem is I would get tired of Jeeps pulling me out of the bogg Russell has just about anything military you could ask for. Jim B. and Rollbar would go nuts in his shop.
Posted 06 May 2008 - 07:55 PM
2. I got my stuff from John @ MidWest Military
I took the light apart to look @ it, notice the rubber mounts
#25
Posted 08 May 2008 - 10:50 AM
No web site available.
No one seemed to notice that I originally painted the fenders garnet and changed them to black.
We wired the lights last night. I also added a set of rear rock lights that will be wired to a rocker switch on my dash. Ever try backing a trailer in the woods at night? I'll try and get more pictures up tonight.
It is scheduled for linex in the morning
Tonight the safety chains go on and some heat shrink on the final wire couplings.
Next week the Diamond plate and hopefully have the tarp made.
#26
Posted 08 May 2008 - 12:18 PM
#27
Posted 08 May 2008 - 02:32 PM
#28
Posted 09 May 2008 - 08:37 PM
#29
Posted 09 May 2008 - 08:40 PM
SWEEEEEEEEEEEEEEeeeeeeeeeeeeettt
#30
Posted 09 May 2008 - 08:51 PM
I'm getting excited now At least I can drag it now, even if the top and diamond plate aren't ready. I accidently deleted the picture with both rock lights. We tried them out last knight. Prety trick. I'm installing them under my Jeep next.
