Suction Cups Radar detector and Sun Pass
Posted 18 April 2008 - 03:09 PM
I talked to one of my friends, and he suggested using vaseline instead of saliva on the suction cups. It's worked! I tried it for a month..........and NO PROBLEMS!
SFJC, Jeep Club Advisor
Posted 18 April 2008 - 04:20 PM
Posted 18 April 2008 - 04:27 PM
'98 Grand Cherokee
Ru•bi•con n.
Posted 21 April 2008 - 05:56 PM
As for the Vaseline thing.......no comment.....lol........but wouldn't it eventually lead to crusting on the windshield from the heat or possible permanent marks?
My Jeep Space
My Mud Space
ShopToEarn.net......give me 5 minutes and you'll see.
Also deleted and edited for everyone's satisfaction.................like Rayne.
Posted 23 April 2008 - 07:56 AM
Posted 23 April 2008 - 01:08 PM
Maybe I've had the problem because I have one of the original Sun Pass holders with the small suction cups...
it is atleast 5 years old.
And, my Radar Detector (as I would NEVER speed) is about 6-7 years old.........and the SUCTION CUPS are
OLD!
Anyway, the vaseline works good!
Posted 24 April 2008 - 08:38 AM
Posted 24 April 2008 - 09:37 AM
Posted 25 July 2008 - 05:25 PM
Posted 25 July 2008 - 08:34 PM
Posted 25 July 2008 - 09:36 PM
Jack H, on Jul 25 2008, 09:34 PM, said:
in case of electrical failure
Posted 25 July 2008 - 09:40 PM
Posted 26 July 2008 - 03:23 PM
Posted 27 July 2008 - 08:46 AM
Posted 30 July 2008 - 10:33 AM
I figure if it works on the windshield of a Kia which is lower than my jeep, it should work inside the console which is higher up. (closer to the DOT receiver)
"This is like deja vu all over again." - Yogi Berra
Posted 30 July 2008 - 12:40 PM
in2jeep, on Jul 27 2008, 09:46 AM, said:
Since April, I have had NO problems with the suction cups. But, I will try your method of cleaning with
Hand Sanitizer........and my window does need some cleaning........both inside and out.
And, I use only a little bit of "petroleum jelly" on the suction cup.
