Market Place Category
Posted 06 April 2008 - 09:34 AM
We are thinking of a Custom modification to the Market place Category which is where all of the 3 For Sale/Wanted Forums reside.
The modification would allow the Topic starter (only) to delete his own topic once the item is sold. Same goes for the Wanted section if the Member already found what he was looking for. We would expect Members to keep this up to date and clean up after their own.
Or instead of the above we can allow the Subject title to be changed by the Topic Starter (only) to note that the item sold or changed as long as the subject is not too long.
We can do one or the other or both, not sure yet.
This will allow to keep the Market place section a bit cleaner and easier for Members on the hunt to be able to spot items that are still active rather than to read through a post only to find out that the item was sold or no longer wanted.
We would like to have some feedback as to what Members think or if it is even worth doing at all.
Thank you,
Admin
Posted 06 April 2008 - 12:03 PM
Good people means my flashlight will NEVER go missing...
Posted 06 April 2008 - 12:20 PM
In this particular case bandwidth is not the problem as JeepTalk has tons, one of the reasons that Gallery members never see red Xs on their photos that they post all over the net.
We believe that it would benefit Members in obtaining the information that they are looking for a bit faster in the Market Place rather than to go through so many topics only to find out that the item is no longer available or needed.
Admin
Posted 06 April 2008 - 10:09 PM
I voted to delete the topic since the seller knows when it sold, there is no need to edit it "Marked as Sold" then delete it. Just do it all in one shot, it may take an extra day but in the end it's all the same, - Deleted.
Posted 07 April 2008 - 09:35 AM
If everything in that particular listing has been sold, then it needs to be deleted.
Posted 07 April 2008 - 12:57 PM
But im just a pack rat and never throw anything away.
'98 Grand Cherokee
Ru•bi•con n.
Posted 08 April 2008 - 08:13 PM
Can the above actually work?
If we were to Custom modified both scenarios, would you want to try one out first and then the other to see which one works best....
Between all the Moderators, we will be able to police this to get the JT Members use to all of this which will actually benefit the section?
We can also modify the guidelines of the actual forum.
I'm thinking not to show the Guidelines because that I have notice that not too many read them but rather create another custom Modification in where the guidelines show above the editing screen while one is actually writing the post. We can also do this in the Let's go Wheeling and Happening section. (this is actually another separate issue)
Admin
Posted 09 April 2008 - 06:02 AM
Admin
IMO, policing themselves willnot work. People as a whole are too lazy.
We should be avble to monitor this as moderators. I do like the idea of having the guideline pop up when they are adding a post.
Posted 09 April 2008 - 09:51 AM
JeepinIan, on Apr 9 2008, 06:02 AM, said:
We should be able to monitor this as moderators. I do like the idea of having the guideline pop up when they are adding a post.
I usually don't jump in with all these new modifications because I really think that most of the time when Admin and I discuss them they are usually to improve where most of us hang out. I have noticed through time that our software forum interface is very powerful on it's stock form. Through out the years there have been some modifications made in addition that we all enjoy once we learn they are there and see other member's using them. Not knocking other forum interfaces but I have not seen any other Jeep forum out there so far that compares to our interface (unless they are using the same, only one other that I know of). And to add to this, JT has all the proprietary custom stuff. Yes it does not come free to a few of us but that is our contribution to all the rest.
What really drives me ballistic at times is that Members that come here day in and day out don't take the time to actually stop a few seconds and learn how to do the simplest of things. If they have problems they don't post in the support forum or bother to read some of the help files or prior postings that really describes in detail how to do it all.
Now, with regards to these modifications, do we really want to stream line the market place to make it easier. I personally would like to see it, even thought there might be only a hand full of postings showing up inside that forum section. It would basically take less time to spot things. Do I think that Members would actually delete or change the subject to sold.... maybe, leaning toward the no.
Here is what I'm more concern about. Not so much as the delete the topic (cut and dry) but the change a subject title. A subject title should be short, brief and to the point. I've seen titles all over JT trying to explain what is inside the topic. I guess we will not know until all of this starts to happen.... if it does. I guess we will have to leave it up to Admin to see which way we go and the easiest way for JT Members to do this.
I also agree with Ian about the guidelines being shown at the top of the editor rather than on the top of some of the forums. Why, because after a while of them being there no one reads them to see if they have been updated, or completely ignore them. Keeping some forums in clean information manner to be able for Members to do things is good so it does not become a free for all taking time in just getting to the useful info. I do notice that some fun is allowed until it starts to get ugly. Than we have the Off topic forums for the rest of the stuff.
Posted 11 April 2008 - 03:30 PM
Change Title (will also edit post)
or
Delete Topic
I guess we can take a look at the few votes and go from there.
Admin
Posted 14 April 2008 - 06:07 AM
or
Delete Topic
Admin
Change title first.
Posted 14 April 2008 - 04:45 PM
Posted 14 April 2008 - 05:20 PM
If the item is still available, then the person could re-list.
After an item is SOLD, or removed from sale, then the listing should be deleted. This would be done when
the person who listed it indicates it is SOLD.
SFJC, Jeep Club Advisor
Posted 14 April 2008 - 10:35 PM
This is a good idea but it requires too many variables and testing of the code. The script routine would not know the difference and all topics in these sections would have a life of 3 months. I can just imagine the requests we would get for a post being wrongly deleted.
Only Moderators can do this now, we are trying to take this responsibility away from them hoping that Members can actually understand how it works and police themselves in these 3 forum sections. I am willing to bet the Moderators will still have to intervene and remind.
For example, look how many members JeepTalk has, how many do you see expressing and giving ideas on this topic. Some people don't comment and that is fine but lets take it a step further and look at the total votes which requires no contribution, replies and it's anonymous. Our IP visit have grown tremendously in the past year and yet......
Sometimes I wonder if we should just stop trying to better JT like we continue doing. Let's just say for now that the ownership, programmers, coders and most of the Moderators including a small population of the membership continues to like and appreciate the small things we do. We hear it behind the scenes and surprisingly we have around a 90% like to 10% complaints out of the ones we do hear from. Can't please everyone but we are glad to see the balance of the scale.
Admin
