Restoring M416 Trailer
Posted 02 April 2008 - 03:51 PM
- I have downloaded write-ups where other people have restored their trailers for reference.
- I plan to keep it military green (but I am not sure of what that actual color is and where I can get it, so any suggestions would be appreciated).
- I want to keep it as close to stock as possible, so I might have some questions as I go through the process.
- I want to pull the hubs to check out the bearings and axles
- I want to remove the tub from the frame to clean up any rust.
- I am not sure of my options to clean and or restore the springs and shocks.
- I plan to keep the existing light configurations but want to convert them over to 12 volt without messing up the 24 volt configuration if possible.
- If I want to restore it with correct placement of emblems and numbers, where do I get the information to do that?
- I may end up building a hard top cover for it but don't know at this point.
Here are some pictures in it's current state: Trailer Pictures
I will take pictures as I go, so I will be able to document the process.
Jim B has already provided me the following information.
With regards to the tarp. Below are a few links:
These guys are a bit on the high side.
http://www.beachwoodcanvas.com/
Weebe webbing is where I get all my stuff from. They are of great quality and good pricing.
http://www.odcloth.com/products.html
Any help and pointers will be greatly appreciated.
Thanks
SFJC and 50/50 Offroad Team
Posted 02 April 2008 - 04:05 PM
Wildbill
Port Charlotte, FL
1992 YJ 4.0 HO
Aussie Lockers Frt & Rear
33 x 12.50 Dunlop Mud Rovers
2004 Liberty Sport 3.7L 4X4
stock for now!!!
Posted 02 April 2008 - 05:42 PM
Posted 02 April 2008 - 10:36 PM
In addition to the Canvas links I gave you I looked at my archives with regards to the Olive Drab paint.
Here is where I purchase all my paint, there are 3 shades depending on the year. The M416 is a later made trailer around the Viet Nam era.
If you go to Rapco paints and click on the drop down menu you will see the shade info. They use to have a nice chart but they must have taking it down.
http://rapcoparts.com/spraypaint.html
Mullins is also a good place for paint.
http://store.mullinsjeepparts.com/mm5/merc...gory_Code=Paint
Here is a complete write up with parts and pics, one of the better links I've had laying around especially for an M416.
http://vegasauto.net/m416.html
For my Willys though I would need to pull a Bantam which is a smaller trailer.
Once you are all done you can can order from Rick larsen Stencils. He makes complete markings for all military. Scroll down and you can see the trailer complete set.
http://www.militarystencils.com/
Below is a link to a detail discussion on Olive Drab shades here on JeepTalk. It has some sample pictures too.
http://jeeptalk.net/...wtopic=1905&hl=
Posted 07 April 2008 - 07:57 AM
Let us know on the progress and take some pics.
Posted 07 April 2008 - 08:40 AM
Update: Over the weekend I started the break down. I have removed all bolts to separate the tub from the frame, I have removed all the 24 volt wiring and lights, and I have removed all the brake components. My next steps will be to remove the axle, springs, and front part of the frame and lunnet.
I am starting to consider my options for the axle and drum repair/replacement, so if anyone has any suggestions I am all ears. At this point I am considering keeping the original look, but you never know as I go through the process.
I will be posting pictures of the trailer in its disassembled phase prior to starting any of the clean up.
Posted 07 April 2008 - 08:13 PM
Posted 07 April 2008 - 08:40 PM
I am going to try my best not to do any wood modifications along the way. When I get ready to paint it I will probably be picking your brain, so be prepared.
Posted 07 April 2008 - 08:41 PM
if you are gonna paint it again ..green or whatever ....please do yourself a favor and use a real spray gun .you will be happier with the result
you know if your interested in getting the paint local there is a paint dist. on st.rd.84 that i deal with these guys are good ....and they even have a special camera that they can take a pic of the paint you have now and mix and match via computer to your exact color you want ....just a thought .
Posted 09 April 2008 - 09:44 AM
I have removed everything off the frame. I need to drop the axle and springs and remove the front hitch/lunnet. I am going to start purchasing the replacement nuts, bolts and supplies either this weekend and next week. Jim, and anyone else serious about helping me restore the trailer, I need to know what I should do about the primer and paint. The other area I need help is the axle (bearings and hubs). I am considering having two sets of hubs, one for the authentic look and one for daily use with standard tires. Let me know your thoughts. I am doing my research but need ideas.
I will be posting pictures later this week or this weekend of the parts before I start the cleanup.
Thanks
Posted 09 April 2008 - 10:58 PM
I need to know if anyone know of somebody that can do sandblasting at a reasonble price. I am not sure if I am going to sandblast the trailer or just do a thorough sanding. The rust is not as bad as I thought even though there are a couple spots that are worst than the rest. Starting next week I will placing my orders for the replacement parts, so it shouldn't be too much longer and it will be back and operational.
I'll keep you posted over the weekend.
Posted 10 April 2008 - 07:17 AM
smokey, on Apr 9 2008, 10:44 AM, said:
Paint you will just have to decide which shade of Olive Drab, now the primer can become really tricky on bare metal. I do know that the same company links I gave you has the red metal primer they use to work with their olive drab. Ask Rollbar, he used some and so did I.
There is all kinds of metal primer that people can recommend but I do have to tell you that I wen to Home Depot and nothing they had there really convinced me except for one that was galvanized but I did not want to take the chance in working with the Olive Drab. When it comes to this I don't have any experience in using that many primers so maybe someone else with paint and body can help out here.
Well if you have the money for two sets of wheel than that is fine. I've seen a few guys have close to authentic and still put the bigger tires on it to match your Jeep size. There is a tire company that makes the bigger military looking size tires also, can't remember the name of the top of my head now.
Posted 10 April 2008 - 07:30 AM
Our club member, Bill E. had his M416 sandblasted. He could give you some info on that. Also, he has posted several pics of his rebuilt trailer. He did an expert job on it.
joe
DAYTONA BEER POLICE MEMBER #6
'04Liberty--3.7L, auto, 4x4
Joe
Posted 10 April 2008 - 09:26 AM
Posted 11 April 2008 - 10:30 PM
Mine isn't in as good of shape as yours and it has been converted to 2" ball. The picture shows the portable lights and wiring i used to get it home. I oredred new military lights today. The brown stuff on the side is clay. I was proud to see it has very little rust. Mine will not be stock in any way shape or form. It will match my CJ7, including a little diamond plating and linex tub. already repacked bearings before dragging it 400 miles home. I will rip it apart starting Saturday. I'm going to try and use all stainless round head bolts. It's the perfect camping trailer. I can't wait to get it done. All the frame work will be PPG DP-90 Black. The outer tub will be PPG garnet red base coat/clear coat and the inside of the tub will be linex w/teflon. I think the wheels will be PPG silver base coat/clear coat.
You asked about paint. The best primer I have ever used is PPG epoxy DP-90. It flexes, but it is very strong. We use it on the bottom of our mowers to prevent the high lift blades from sandblasting through the decks. These mowers mow around 500acres a week.
Any how, congradulations on the find. If mine was as nice as yours, I would restore to original also. For sandblasting check w/ local headstone makers, they will sometime let you rent their sand and sandblater for $6.00 to $10.00 per hr.
Good luck and keep us posted.
Posted 13 April 2008 - 03:02 PM
smokey, on Apr 10 2008, 09:26 AM, said:
Bill is "SafariOutfitter" on the forum. He will be a good source.
Joe
Posted 13 April 2008 - 03:32 PM
After I put it together from the shipper
Some surface rust spots that came out easily.
I bought a canvas from Northern tool and inserted the grommets... didn't work too well after a
70 mph test run, however. I used black and two shades of brown "rattle can" Camo paint. I may
LineX the underside and the inside soon.
I left the original tires on it. It tracks behind me perfectly and my Jeep gas mileage doesn't seem
to be affected. I've taken it to Tellico and more recently to Titusville for the Sgt. Ryka event.
I'm very happy with it. I now have two spare tires for it as well.
Joe
Posted 13 April 2008 - 04:54 PM
Sky6 thanks for the contact for bill and nice looking trailer. I will try to track him down.
Posted 13 April 2008 - 06:01 PM
Very nice. I like the camo you chose.
Posted 14 April 2008 - 06:33 AM
Like the camo and glad you kept the look of the tires.
With regards that canvas cover.... how could you.
And btw, if and when you move, if you have a problem taking it with you I would be happy to store at my place.
Now all we have to wait is on the pics that Smokey supposedly has been taken. Would like to see it off the frame with pics of the frame and bottom of tub.
Sodman, nice find but you will have to hunt down a lunette for it.
Posted 14 April 2008 - 08:38 AM
Hey Joe, is that authentic camo pattern. I found a book somewhere online that showed the approved army camo pattern and I don't remember if that is the correct pattern. I had considered camoing mine, but I didn't want to go through the extra aggravation.
Posted 14 April 2008 - 12:27 PM
smokey, on Apr 14 2008, 09:38 AM, said:
Looking forward to those pics and the surprise. Regarding my pants... I have not been able to find them for over 10 years now.
Posted 14 April 2008 - 11:27 PM
Now the fun really begins!
Posted 15 April 2008 - 06:59 AM
Yep, you definitely have it under control with the wife having it all on the front driveway.
#25
Posted 16 April 2008 - 06:53 AM
No, it is only a pattern that seemed to fit. I camoed my canoe the same way.... a rattle can in each hand... if I don't like, I just keep going until it looks nice to me.
Once while in the military I was in charge of my companies vehicles, I was told to camouflage them. We had two 2 1/2 tons, 2 5/4 tons, and 3 Jeeps (we were leg infantry or we would have had more transportation)... no rattle cans just buckets and brushes. We went to work that day... everyone said it looked nice but that the patterns were not coming in until the following week... I said, "patterns"? Yep, I had to redo all of them.
Joe
#26
Posted 20 April 2008 - 03:33 PM
#27
Posted 22 April 2008 - 03:17 PM
I am done stripping the trailer and have begun working on the tub. I will post the final stripped pictures prior to the painting process.
I still need to buy the replacement bolts, one tire because one is dry rotted, and lighting.
I'll keep you posted.
#28
Posted 24 April 2008 - 09:12 AM
I'm looking forward on your thoughts with regards to the paint. I knew Rapco would help you out with year color and special primer. Let us know what they told you with regards to the shades and different kinds of primer. Thanks.
#29
Posted 10 May 2008 - 09:28 PM
When you locate the tires please let me know how much. I found the direct replacements, but $90.99 each I'll put some cheap Coopers or something before I pay that for a millitary tread. They are only 4ply.
Thanks, J. Brown
#30
Posted 15 June 2008 - 01:33 PM
Here are the photos.
Sorry for the glare on a couple of the pictures. Once I am done I will do a complete write up...
