Had to brace the windshield - Not sure why, but had to until I install the new/used one that has been here for 6 months. Been busy. So here is a tech tip for windshield bracing.
1. Get a "L" bracket from Lowe's.
2. Cut it in half. P.S. This is one Peach bought a while ago so I could hang a shelf.
3. Bend it to fit the windshield hinge & frame.
4. Sand windshield to get a good ground.
5. Take the welders ground & clamp the brace in place so U can weld it on.
6. Set the temp to low so U don't burn through the windshield frame like I did & have to fill it.
7. Take some camo spray paint & touch up your work.
8. Install new/used windshield in 6 more months.
CJ Windshield Bracing
Posted 21 March 2008 - 01:41 PM
Posted 21 March 2008 - 02:46 PM
Wonder why it needed the bracing :D
Posted 23 March 2008 - 01:45 PM
I'm not sure either.... don't they make a spray that takes care of all of this?
Posted 25 March 2008 - 08:37 AM
wow that is some serious rust u got there
Official Mall Crawler
Posted 25 March 2008 - 07:14 PM
Tell'em boyz, that's not rust, thats air vents & water drainage
Posted 27 April 2008 - 09:22 PM
Did you weld that, or is that the results of overhead pigeons ???
Real Jeeps are BUILT ! All others are for haulin groceries and babies...
