I know many people don't like going 2 inches on a body lift but I figured I won this one at one of the past jeep shows so I figured I would put it to good use. I installed it last night on my own with no problems. Sorry no in progress pictures because it was dark and I was the only one working on it. I had no problems with the install and it seems to ride well and no problems with the shifters (automatic). Let me know your thoughts.
Before lift:
After lift:
2 Inch BDS Body Lift
Posted 09 March 2008 - 06:30 PM
Help A Fellow Jeeper Out!
SFJC and 50/50 Offroad Team
Posted 09 March 2008 - 06:38 PM
i like it!, i will put in a good word for you at jubicon express!
Posted 09 March 2008 - 06:48 PM
I am already working on a minor modification to hide the mounts in the front, so you might even be more impressed with me when you see that... Time will tell.
Posted 09 March 2008 - 08:14 PM
Turned out rather well. Doesn't look like a 2" compared to some of the ones I've seen.
Posted 10 March 2008 - 09:12 PM
Looks nice....now all you need are some new tires. with 4'' lift you should be able to fit 36''
Posted 11 March 2008 - 07:41 AM
Up to 2"s is acceptable, anything higher depending on your wheeling can cause some issues. Not to mention the install modifications on a 3" and up to make it work properly.
Btw, check your 4x4 engagement and make sure it works properly, you should be ok but it's always good to check.
Looking good there Smokey!
