Snorkel Mod - Paint Work
Posted 05 February 2008 - 07:11 PM
i took the snorkel to the fab shop and after doing a few measurements ....we came up with a design to accomidate the ever present problem of losing a light bar when a snorkel is added with minimal inpact to the snorkels original design .
well i wasnt doing that .
first step . we measured out the feed tube that fits into the fender and ext.it out 4 inches .
then we added a body flange that when bolted on will sit snuggly up against the fender body side with an added on clamp for point reinforsement ........note: the added body ext flange not only adds to the body/style looks of the snorkel ...it also protects the feed tube well being 1/4 " thick alum.
next step . we measured out the spacer distance 2.5" we needed when the piece is bolted on to the shared windsheild bracket and fabricated a spacer block out of 1/4 " alum and drilled that to fit .
added bonus ....we drilled a drain hole at the lowest point of the snorkel and installed a brass drainplug .
next step : with all mods/ done we sanded down all welds and entire piece to a smooth raw alum finish then it was finished up by being watertight tested .
nextstep ..primer/paint . first i applied 2 coats of Y94 anti-corrosive (green in color ) to entire piece . next i then applied 3 coats of white epoxy finish primer . total dry time 4 hrs .then the piece was sanded with 320-400 to a smooth finish .
next the snorkel was washed with soap and water ...washed down with prep-sol .tacked ..then i applied 3 coats of Red chroma1
topcoat to match my jeeps color perfectly .
i just uploaded 55 + pics to my space page which shows all work done in detail check them out ...
click on the link below my signature and then click on pics on my page then click on snorkel fab/paint .
when i install i will post more updated pics .
Check them out ....let me know what you think ...
Posted 05 February 2008 - 07:34 PM
June 26. 1988 - August 29, 2008
2005 Dodge Neon SXT - Full ACR suspension swap, 2" lowering springs, 17" SRT rims, CAI, Cat - Back, 5 speed, stage 2 clutch, strut tower bars, sway bars - Autocross Car/Daily Driver
1990 Jeep XJ - Gettin ready to make a scene.
www.FortMyersRacing.net
www.SWFLRacing.com
www.SouthernMudding.com
Posted 05 February 2008 - 08:07 PM
Posted 06 February 2008 - 08:10 AM
But... you need to link the pics to the post so that dumb guys like me can follow the write up with visual.
Give the links to the moderator and they will add it to the post.
Posted 06 February 2008 - 08:16 AM
o do was "just" paint and install it but nooooooooo it had to have that special touch
CJ7 Swamp Buggy
Posted 06 February 2008 - 02:36 PM
Posted 06 February 2008 - 07:59 PM
anyway its on and solid /
nothing left to do now except run the plumbing .
installed pics up on myspace .
Posted 06 February 2008 - 08:01 PM
2004 Jeep Grand Cherokee 4x4 Overland Edition
4.5" Rusty's Lift kit and some interesting mods.
2001 Toyota Tacoma 4X4 Extracab
4" Lift but mainly a Hunting Truck but still alot of fun.
Macon Ga just 1 hour from River Rock.
Posted 06 February 2008 - 08:32 PM
Posted 07 February 2008 - 08:02 AM
Try to upload to imageShack.
Go here: Posting Pics
Posted 07 February 2008 - 09:37 AM
Posted 07 February 2008 - 11:52 AM
Posted 07 February 2008 - 01:20 PM
Posted 07 February 2008 - 02:46 PM
thank you for that lil photo asst
i wish i could figure out how to do that .....
snorkel ....almost done ...except for the plumbing ..... new susp.lift on the way ............
Posted 07 February 2008 - 05:25 PM
Got a question, does not the River snorkel mount a bit higher on the side horizontal to the top of the fender Or is this a different for a different model.
I was not aware that you can link myspace pics into the post, keep them coming
Posted 07 February 2008 - 06:22 PM
waiting on somebody with alittle more knowledge in that air box connection area to give me an asst with that part . im hoping beggin works in this area ........oooooohhhhh please somebody help me with this part
Posted 08 February 2008 - 07:49 AM
I do remember seeing this on his vehicle that was on display but now that I think about it... it was a JK which probably has the room to go higher.
From the pics the spacer came out really good. Would like to see a picture of the attachment up on top near the light bar if you get a chance.
Posted 08 February 2008 - 03:28 PM
workin on pics of the new guard plate
Posted 08 February 2008 - 05:55 PM
