Does any one here have any experience with old Starters
Battery is good, electrical is good. When she cranks the starter sounds like it can't get out of bed at times with a binding sound and then she turns.
Could it be going bad
Willys MB Starter
Posted 15 January 2008 - 07:49 AM
Posted 15 January 2008 - 05:47 PM
1. Could be one of the contact windings is broken/barley on if U know what I mean.
2. Bushing worn out & front gear teeth binding until it makes contact w/the flywheel then centers it self on the flywheel & rides it, thus, not binding/grinding anymore.
3. Ground.
4. Let me have the Jeep for a while to check it out & then I'll give it back in oh, say, 2199
3. Ground.
Posted 18 January 2008 - 08:14 AM
Can this be easyly fixed on the old girl
Can this be easyly fixed on the old girl without buying a new starter
3. Ground.
I'ts not ground
Posted 18 January 2008 - 05:07 PM
Pull the starter & C what U have. If it is bushings/brushes, yes. Check the end play on the gear for slop as it rides on the shaft. U can ground the starter & jump it w/jumper cbls to see what is going on.
P.S. R U missing any bolts that hold it in
