Cable Crimper & Post Hole Digger
Posted 14 January 2008 - 10:55 AM
I am relocating the control soelinoids for my winch under my hood and need to make up new cables and I don't want to buy a crimper.
If anyone can help me out, thanks.
Also, I am moving some fence at my house and need to dig some holes for the posts.
If anyone has the clamp type post hold digger I can borrow.
Email me
Thanks
Dan
3.5 Rubicon Express Super Flex
ProComp 33x12.5 XTerrain
Piss off a Republican, work hard, play hard and think.
Posted 14 January 2008 - 11:05 AM
Email me
Thanks
Dan
I have a pole digger (manual not the drill type) if you need it I have it at my shop in hallandale, call me you have my number
Gustavo
Posted 14 January 2008 - 11:40 AM
I'm planning on doing this same thing. i'm going to move the solenoid box to the inside fender well and then wire the remote to the dash. plans are for a 3 position rocker switch to arm the winch (wired controls - off - wireless remote) and a 2 position rocker for the feed (in - out). in that the heater has been removed, i'm building a 6 switch panel plate which fits the dash space fine. both the housing and waterproof rocker switches can be found at west marine, if you're interested in anything similar.
ps - since we eradicated the front bumper and tow bar mounts at holey lands this weekend, i bet you get around to this project before i do. i'll be curious to see how you do it.
Posted 14 January 2008 - 11:44 AM
Gus, can you bring it by this weekend when we go diving?
Dave. I am planning on somthing similar I havent decided how to run the switch though. I know I don't want to have a dash mounted swtich though. I may just rewire the existing hand swich with new plugs.
Posted 14 January 2008 - 11:47 AM
Dan and Dave, you guys might want to check www.12voltguy.com he has what you need and the diference in price might not be much.
Posted 14 January 2008 - 12:01 PM
fishalways, on Jan 14 2008, 11:44 AM, said:
can you splice a disconnect into the line and run it through a spare hole in the firewall? that way you could plug the pendant in when you need it but not loose the space when you don't. i'm not familiar w/ the tj too much, but my firewall has several opening where i've added a grommet and pulled wire. where the leads currently leave the solenoid, i fed then through some radiator hose for when they went through the body...no chance of chafing. just a thought...
TallJeep, on Jan 14 2008, 11:47 AM, said:
tiredpete bought his dash winch plate from him and i'm well aware of him (excellent work). he gets a little pricey on custom work, especially when waterproof components are required. plus...even though i rarely get it right on the first time, i like doing the work myself (and then there's that i'm so tight that i squeak when i walk thing ) i pressure wash the entire jeep...dash and all so i need the waterproofing.
ps - depending on where you get the cable and leads from, you should be able to rent/borrow a crimper (A-zone?)
Posted 16 February 2008 - 10:10 AM
fishalways, on Jan 14 2008, 11:55 AM, said:
not sure where you are in this project...just starting mine. I've found that the larger west marine stores sell 2/4 ga battery cable by the foot and have a workbench w/ a crimper that you can use for free.
Posted 16 February 2008 - 08:18 PM
LrdJeffson, on Feb 16 2008, 10:10 AM, said:
I haven't had a chance to get into it but maybe next weekend now that I am working again.
Don't forget to take pics.
Posted 16 February 2008 - 09:43 PM
I have a heavy duty crimper if you still need it. Does 8 awg to 2/0 awg. Might even have connectors depending on the guage cable. Call me, I'll hook you up.
