Try a few drops of hydrogen Peroxide on the threads where it can leech into the threads.
Use a cotton ball or some threads wrapped around the area to hold the peroxide if you can't get gravity to work for you.
Keep it wet for about 30 minutes, then try breaking them loose...
Breaks the rust bonds between the metal parts.
Not sure if it will work if the joint is packed full of petroleum distillates or not, but on dry rust, it works pretty good, especially if the bolts were zinc plated from the factory.
Hydrogen Peroxide for Rust
Posted 30 December 2007 - 04:09 PM
Posted 30 December 2007 - 10:03 PM
Sounds like a great tip......... I'll try and remember it next time I'm without any PB Blaster
Wildbill
Wildbill
Yale H.
Port Charlotte, FL
1992 YJ 4.0 HO
Aussie Lockers Frt & Rear
33 x 12.50 Dunlop Mud Rovers
2004 Liberty Sport 3.7L 4X4
stock for now!!!
Port Charlotte, FL
1992 YJ 4.0 HO
stock for now!!!
Posted 31 December 2007 - 06:18 AM
Something to think about specially those bolts from a car trailer. Sure is cheaper.
