Set Timing Using Vacuum Gauge yes or no
Posted 24 December 2007 - 07:10 PM
Class is in:
1. Now, would this be more accurate in combination w/a timing light.
2. What is the best desired vacuum for a 258 CI engine?
3. Would you be better off setting your engine to the specific vacuum instead of what the book says (i.e using the marks on the flywheel).
Posted 26 December 2007 - 07:21 AM
Posted 26 December 2007 - 02:21 PM
Posted 26 December 2007 - 04:41 PM
So, what about #2, 3.
JeepinIan, on Dec 26 2007, 07:21 AM, said:
Ya, I to usually do that also Ian & it helps get it close. I was just wondering about #2, 3 to see if there were specifics.
Posted 26 December 2007 - 07:36 PM
That's why there are timing marks. Otherwise everyone would use a vacuum gauge
Posted 26 December 2007 - 08:24 PM
all timing marks are adequate not actual. all fuel is not the same.
so for the best performance with the acquired fuel do it by ear and make sure it cranks over easily for every day use.
Posted 26 December 2007 - 08:39 PM
TranyDoctor, on Dec 26 2007, 08:24 PM, said:
like tranny fluid
P.S. Ian, I should have specified with great specificity, stock engine/config w/a carter 2bbl. I for got what I was pull for vacuum (18-20" if memory serves), my gauge is down South. I use to run a vacuum gauge/meter in my old car I had @ high school, I raced a lot. :sneak:
Posted 26 December 2007 - 08:49 PM
Rollbar, on Dec 26 2007, 08:39 PM, said:
keeps me roll-in-roll-in-roll-in rahide
18-20 is great for idle, but what happens with throttle
Posted 26 December 2007 - 09:02 PM
TranyDoctor, on Dec 26 2007, 08:49 PM, said:
(If memory serves, or the gauge drops to....) but, I'm thinking it drops to zero when I punch it by hand @ the linkage. I have to get it up here & check it but the wife wouldn't know where to look.
Posted 26 December 2007 - 09:12 PM
Posted 26 December 2007 - 10:33 PM
Posted 26 December 2007 - 10:39 PM
Posted 26 December 2007 - 10:42 PM
P.S. Thanks guys
